HP DeskJet 3700 Printers - Very Slow Printing (Windows 10)
This document is for HP DeskJet 3730, 3752, 3755, DeskJet Ink Advantage 3775 and 3785 All-in-One printers with Windows 10 computers.
The printer prints very slowly. The approximate printing time of one page of text is 23 seconds, but some print jobs can take up to 8 minutes to print when the paper type is set to HP Glossy Brochure or Profession Paper.
Step 1: Change the default paper type
Make sure the default paper type in the print driver is set to Plain Paper.
  1. Search Windows for printers, and then click Devices and printers in the list of results.
  2. Double-click the HP DeskJet 3700 series icon.
  3. Double-click Set Preferences.
  4. Click the Paper/Quality tab.
  5. In the Paper type drop-down menu, select Plain Paper, and then click OK.
    Figure : Selecting the Plain Paper setting
  6. Close the HP DeskJet 3700 series window, and then close the Devices and Printers window.
Try to print. If the printer continues to print slowly, continue to the next step.
Step 2: Uninstall the print driver
Remove the print driver and software using the Uninstall a program tool in Windows Programs and Features.
  1. Search Windows for programs and features, then click Programs and Features in the list of results.
  2. In the list of installed programs, click your HP printer name, then click Uninstall then Yes.
  3. Follow the on-screen instructions to complete the software removal.
  4. Restart the computer.
Step 3: Reinstall the print driver
After uninstalling the print driver and restarting the computer, download and install the latest version of the full feature software.
  1. Go to 123.hp.com/dj3700 to download the latest print driver.
  2. Install the software according to the instructions on the HP website.
Try to print. If the issue persists, continue to the next step.
Step 4: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
