    Fix HP Printer issue on macOS
HP EliteDesk 705 G3 Desktop Mini Business PC - Specifications
Operating systems
Specification
AMD B300 FCH
Preinstalled (Windows)* **
Windows 10 Pro 64
Preinstalled (other)
FreeDOS 2.0
NeoKylin Linux 64
Web-supported
Windows 10 Pro 64
Windows 10 Enterprise 64
Tested and documented
Windows 7 Professional 64*
*HP intends to test the available Windows 7 Professional drivers and document how they perform. Some device drivers might not be certified by Microsoft.
*This product does not support Windows 8 or Windows 7. In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on this product or provide any Windows 8 or Windows 7 drivers.
**Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Processors
Specification
AMD PRO A12-9800E with AMD Radeon R7 graphics
35 W
Up to 3.8 GHz maximum boost frequency (3.1 GHz base frequency)
2 MB L2 cache, 4 cores, 8 Radeon cores
Discrete-class graphics
DDR4 memory up to 2133 MT/s data rate
AMD DASH 1.1 supported
AMD PRO A10-9700E accelerated processor with AMD Radeon R7 graphics
35 W
Up to 3.5 GHz maximum boost frequency (3.0 GHz base frequency)
2 MB L2 cache, 4 cores, 6 Radeon cores
AMD PRO A6-9500E with AMD Radeon R5 series
35 W
Up to 3.9 GHz maximum boost frequency (3.2 GHz base frequency)
1 MB L2 cache, 2 cores, 4 Radeon cores
Multi-core is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of clock speed.
Software/security
Specification
BIOS
HP BIOSphere with Sure Start
Available only on business PCs with HP BIOS.
HP DriveLock
HP BIOS protection
BIOS update via network
Master boot record security
Power on authentication
Pre-boot security
Secure erase
HP Spare Key
Requires initial user setup.
Hybrid boot
Measured boot
Secure boot
Absolute persistence module
Activated when customers activate a purchased subscription.
Preboot authentication
Multimedia
CyberLink Power media player
Native Miracast support
HP value add software
HP ePrint driver
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Recovery Manager
HP Support Assistant
HP JumpStart
Microsoft products
Bing search
Skype for Business certified (Not available in China)
Manageability
HP Driver Packs*
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)*
HP BIOS Config Utility (BCU)*
HP Client Catalog*
HP CIK for Microsoft SCCM*
LANDESK Management**
Discover HP Touchpoint Manager
HP Image Assistant*
*Available for download.
**Subscription required.
Security
HP Security Manager (including Credential Manager and Password Manager)
HP DriveLock
HP Password Manager
Microsoft Defender*
*Opt in and internet connection required for updates.
Trusted platform module TPM 2.0 embedded security chip (SLB9670 - Common Criteria EAL4+ certified)
SATA 0, 1 port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Setup password (via BIOS)
Solenoid hood lock/Intrusion sensor
Chassis padlocks and cable lock devices supported
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Graphics/audio/multimedia
Specification
System integrated graphics
AMD Radeon HD graphics
Audio
DTS Studio Sound with Realtek codec ALC221
Microphone and headphone front ports, 3.5mm (.14 in)
Internal mono speaker (standard)
HP UC speaker phone*
HP UC speaker phone mounting bracket*
*Optional and must be configured at purchase.
Memory/storage
Specification
Memory
DDR4-2133 (Transfer rates up to 2133 MT/s)
Memory modules support data transfer rates up to 2133 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
32 GB
Full availability of 4 GB or more of memory requires a 64-bit operating system.
(2) SODIMM slots
6.35 cm (2.5 in) 7.2k rpm hard disk drives
1 TB SATA
500 GB SATA
500 GB SATA, 2nd
6.35 cm (2.5 in) solid state hybrid drives (SSHD)
1 TB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid
1 TB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid, 2nd
500 GB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid
500 GB 5400 rpm 6.35 cm (2.5 in) 8 GB hybrid, 2nd
6.35 cm (2.5 in) self-encrypting drives (SED)
500 GB 5400 rpm 6.35 cm (2.5 in) federal information processing standard (FIPS) SED, 2nd
500 GB 7200 rpm 6.35 cm (2.5 in) SED Opal 2
512 GB SED SSD Opal 2 drive
512 GB SED SSD Opal 2 drive, 2nd
512 GB SATA SED SSD Opal 2 TLC
HP Turbo Drive G2 solid state drives
HP 128 GB Turbo Drive G2 SSD M.2 drive
HP 256 GB Turbo Drive G2 SSD M.2 drive
HP 512 GB Turbo Drive G2 SSD M.2 drive
HP 256 GB Turbo Drive G2 TLC SSD M.2 drive
HP 512 GB Turbo Drive G2 TLC SSD M.2 drive
6.35 cm (2.5 in) SATA solid state drives
HP Value 128 GB SSD drive
HP Value 128 GB SSD drive, 2nd
HP Value 256 GB SSD drive
HP Value 256 GB SSD drive, 2nd
Intel Pro 5400s 240 GB SSD drive
Intel Pro 5400s 240 GB SSD drive, 2nd
HP 256 GB TLC SSD drive
HP 256 GB TLC SSD drive, 2nd
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) of system disk is reserved for the system recovery software.
Networking/communications
Specification
Ethernet (RJ-45)
Broadcom NetXtreme Gigabit Ethernet LOM BCM5762 - DASH compliant NIC
Wireless LAN (optional)*
Intel 8260 802.11AC 2 x 2 DualBand M.2 combo card
Intel 7265 802.11AC 2 x 2 DualBand M.2 combo card
Intel 3165 802.11AC 1 x 1 SingleBand M.2 combo card
*Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Slots/ports/bays
Specification
Slots
(1) Turbo drive M.2 PCLe x1-2230 for WLAN
(1) Turbo drive M.2 PCLe x4-2280 for storage
Ports
(2) USB 2.0, rear
(4) USB 3.1 Gen 1: (2) front, (2) rear
(1) VGA
(1) DisplayPort
(1) HDMI, 2nd DisplayPort, or Serial (RS-232) connector (optional)
(1) Headphone/microphone, front
(1) Headphone connector, front
(1) RJ-45 connector
(1) DM SATA storage connector
Bays
(1) 6.35 cm (2.5 in) internal storage drive bay
Keyboards/pointing devices
Specification
Keyboards
HP Conferencing keyboard
HP USB Business Slim keyboard
HP Grey USB keyboard
Mice
HP USB 1000 dpi laser mouse
HP Grey mouse
HP USB mouse
HP USB mouse (China only)
HP USB Hardened mouse
Combo
HP Wireless Business Slim keyboard and mouse
HP USB keyboard and mouse (China only)
Other
HP mouse pad
Keyboards and pointing devices are optional and must be configured at purchase.
Adapters/cables
Specification
Adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort to DVI-D adapter, 2nd
HP DisplayPort to HDMI 4K adapter
HP DisplayPort to HDMI 4K adapter, 2nd
HP DisplayPort to VGA adapter
HP DisplayPort to VGA adapter, 2nd
Cables
HP DisplayPort cable
HP DisplayPort cable, 2nd
HP DVI cable (with DisplayPort to DVI Adapter installed)
HP 700 mm DisplayPort cable kit
Adapters and cables are optional and must configured at purchase.
Power supply specifications
Specification
Power supply
External
Standard efficiency
65 W active PFC, 89% average efficiency
90 W active PFC, 89% average efficiency
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency
47 – 63 Hz
Rated input current with energy efficient power supply
65 W/1.7 A
90 W/1.4 A
DC output
19.5 V
Current leakage (NFPA 99)
Less than 500 microamps of leakage current at 120 VAC with the ground wire disconnected, as required for non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 microamps of leakage current at 120 VAC with the ground wire intact with normal polarity, as required for non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power cord length
1.83 m (6 ft)
Weight/dimensions
Specification
Chassis (W x D x H)
177 x 175 x 34 mm (6.97 x 6.89 x 1.34 in)
Horizontal orientation
System volume
1.05 L (62.79 cu in)
System weight
1.3 kg (2.86 lbs)
Stand dimensions (W x D x H)
117 x 160 x 19.5 mm (4.6 x 6.3 x .77 in)
Packaging (W x D x H)
198 x 290 x 500 mm (7.8 x 11.42 x 19.7 in)
Shipping weight
4.1 kg (9.04 lbs)
Palletization profile
(8) units per layer
(10/12) layer maximum*
(80/96) units per pallet*
119.7 x 99.8 x 252.1 cm (47.13 x 39.29 x 99.25 in) (including pallet)
Depending on whether 12.19 m (40 ft) standard sea container or 12.19 m (40 ft) high-cube sea container is used.
Weights and dimensions configured with 1 hard disk drive.
