HP PCs - Using the HP Sure View Integrated Privacy Screen
This document is for HP notebooks and ZBooks with HP Sure View installed.
HP Sure View protects sensitive information visible on your computer screen by making it difficult for onlookers to view from the sides. This feature can be easily turned off or on using the function keys. An HP Sure View privacy panel is required to use the privacy feature.
