Product Specifications for the HP LaserJet Ultra MFP M134a Printer (G3Q66A)
Product naming
Model name
G3Q66A
What's included and accessories
What's in the box
HP LaserJet Ultra MFP M134a; HP LaserJet toner cartridge; HP LaserJet imaging drum; Power cord; USB cable (Asia Pacific and Japan only); Getting Started Guide; Set Up poster; Support flyer; Printer documentation and software on CD-ROM
Connectivity
Ports
1 Hi-Speed USB 2.0 (device)
Direct print supported
USB printing
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimize; Paper; Multi-Page Copy; Draft Mode
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 22 cpm
Copy resolution
600 x 400 dpi
Environmental
Acoustic power emissions
6.5 B(A) (printing at 23 ppm)
Operating humidity range
30 to 70% RH
Storage humidity
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25ºC
Recommended operating temperature range (Fahrenheit)
63.5 to 77ºF
Storage temperature range (Celsius)
-20 to 60ºC
Storage temperature range (Fahrenheit)
-4 to 140ºF
Environmental specifications
Mercury free
Memory
128 MB
Mobile printing capability
Mobile printing services
Apple AirPrint
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6, B5 (JIS)
Media sizes supported (U.S. standard)
Letter; Legal; Executive; 8.5 x 13 in; envelopes
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Paper (laser, plain, photo, rough, vellum), envelopes, labels, cardstock, postcards
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
398 x 482 x 387.9 mm
Maximum dimensions (W x D x H, U.S. standard)
15.7 x 19 x 15.3 in
Weight (metric)
6.8 kg
Weight (U.S. standard)
15 lb
Power
Energy savings feature technology
HP Auto-on/Auto-off Technology
Internal
Power supply
110-volt input voltage: 110 to 127 VAC (+/- 10%), 60 Hz/50 Hz, 4.8 A; 220-volt input voltage: 220 to 240 VAC (+/- 10%), 60 Hz/50 Hz, 2.8 A
Power consumption
255 watts (active printing), 4.2 watts (ready),1.0 watts (sleep), 0.05 watts (Auto Off/Wake on USB, enabled at shipment), 0.05 watts (Auto-off/Manual-on), 0.05 (Manual Off)
Print cartridges
Number of print cartridges
3 Black
Replacement cartridges
HP 33A Original Black LaserJet Toner Cartridge, CF233A; HP 34A Original LaserJet Imaging Drum, CF234A
Printing specifications
Print technology
Laser
Duplex printing
Manual duplex
Print resolution (best)
Up to 600 x 600 dpi, HP FastRes 1200 (1200 dpi quality)
Maximum print area (metric)
214 x 356 mm
Maximum print area (U.S. standard)
8.4 x 14 in
Monthly duty cycle
Up to 20,000 pages
Print languages
PCLmS, URF, PWG
Printer smart software features
Apple AirPrint, Instant-on Technology, JetIntelligence cartridges
Regulatory specifications
Regulatory model number
SHNGC-1501-00
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/ EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011+A2:2013; IEC 60825-1:2007 / EN 60825-1:2007 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 - Class B, EN 61000-3-2:2006 +A1:2009 +A2:2009, EN 61000-3-3:2013, EN 55024:2010, FCC Title 47 CFR, Part 15 Class B / ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Scan
Scan technology
CIS
Scan speed (normal)
Up to 11 ppm
Scan resolution, hardware
Up to 600 x 600 dpi (color, flatbed), Up to 1200 x 1200 dpi (mono, flatbed)
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8
Minimum system requirements for Macintosh
Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks): 1 GB available hard disk space, Internet required, USB
Compatible network operating systems
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks), v10.8 (Mountain Lion): 1 GB available hard disk space, Internet required, USB. Linux (For more information, see http://hplipopensource.com/hplip-web/index.html).
One-year limited warranty
