    We are upgrading our website
Product Specifications for the HP LaserJet Pro MFP M132fw Printer (G3Q65A)
Product naming
Model name
G3Q65A
What's included and accessories
What's in the box
HP LaserJet Pro MFP M132fw; HP LaserJet toner cartridge; HP LaserJet imaging drum; Power cord; Phone cord; USB cable; Getting Started Guide; Set Up poster; Support flyer; Printer documentation and software on CD-ROM
Connectivity
Ports
Hi-Speed USB 2.0 port (device); built-in Fast Ethernet 10/100Base-TX network port; Phone line port (in/out); Wireless
Wireless capability
Standard (Wi-Fi 802.11b/g/n)
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimize; Paper; Multi-Page Copy; Draft Mode
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 23 cpm
Copy resolution
600 x 400 dpi
Environmental
Acoustic power emissions
6.5 B(A) (printing at 23 ppm)
Operating humidity range
30 to 70% RH
Storage humidity
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25ºC
Recommended operating temperature range (Fahrenheit)
63.5 to 77ºF
Storage temperature range (Celsius)
-20 to 60ºC
Storage temperature range (Fahrenheit)
-4 to 140ºF
Environmental specifications
Mercury free
Fax
Fax available
Yes
Fax resolution
Up to 300 x 300 dpi (halftone enabled)
Fax memory
Up to 1,000 pages
Telephone handset supported
Yes
Fax telephone mode supported
Yes
Modem
33.6 kbps
Speed dials, maximum number
Up to 120 numbers (119 group dials)
Fax transmission speed
3 sec per page
Memory
256 MB
Mobile printing capability
Mobile printing services
Apple AirPrint; HP ePrint; Google Cloud Print 2.0; Mopria-certified; Wi-Fi Direct
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/ DHCP/ AutoIP; WINS; SNMP v 1/2/3; and HTTP/HTTPS
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; B5 (JIS)
Media sizes supported (U.S. standard)
Letter; Legal; Executive; 8.5 x 13 in; envelopes
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Paper (laser, plain, photo, rough, vellum), envelopes, labels, cardstock, postcards
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Paper handling - ADF
Automatic document feeder capacity
35 sheets
Media size (ADF)
A4; Letter; Legal
Media weight supported, ADF (metric)
70 to 90 g/m²
Media weight supported, ADF (U.S. standard)
18.5 to 24 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
423.1 x 511.4 x 423.7 mm
Maximum dimensions (W x D x H, U.S. standard)
16.7 x 20.1 x 16.7 in
Weight (metric)
7.6 kg
Weight (U.S. standard)
16.8 lb
Power
Energy savings feature technology
HP Auto-on/Auto-off Technology
Internal
Power supply
110-volt input voltage: 110 to 127 VAC (+/- 10%), 60 Hz/50 Hz, 4.8 A; 220-volt input voltage: 220 to 240 VAC (+/- 10%), 60 Hz/50 Hz, 2.8 A
Power consumption
255 watts (active printing), 4.2 watts (ready),1.0 watts (sleep), 0.05 watts (Auto Off/Wake on USB, enabled at shipment), 0.05 watts (Auto-off/Manual-on), 0.05 (Manual Off)
Print cartridges
Number of print cartridges
1 Black
Replacement cartridges
HP 18A Original Black LaserJet Toner Cartridge, CF218A; HP 19A Original LaserJet Imaging Drum, CF219A
Printing specifications
Print technology
Laser
Duplex printing
Manual duplex
Print resolution (best)
Up to 600 x 600 dpi, HP FastRes 1200 (1200 dpi quality)
Maximum print area (metric)
214 x 356 mm
Maximum print area (U.S. standard)
Monthly duty cycle
Up to 10,000 pages
Print languages
PCLmS, URF, PWG
Printer smart software features
HP ePrint, Apple AirPrint, Instant-on Technology, HP Auto-On/Auto-Off, JetIntelligence cartridges
Regulatory specifications
Regulatory model number
SHNGC-1501-04
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/EN60950-1:2006 +A11:2009 +A1:2010+A12:2011+A2:2013; IEC 60825-1:2007 / EN 60825-1:2007 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 - Class B, EN 61000-3-2:2006 +A1:2009 +A2:2009, EN 61000-3-3:2013, EN 55024:2010, FCC Title 47 CFR, Part 15 Class B / ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Telecom compliance (fax capability)
Wireless telecommunications: EN 301 489-1 V1.9.2 / EN 301 489-17:V2.2.1; EN 300 328: V1.9.1 / EN301 893 V1.8.1; FCC Title 47 CFR, Part 15 Subpart C & E / RSS 247 Issue 1, 2015 & RSS 102 Issue 5, 2015; IEC 62311:2007 / EN62311:2008; Fax Telecom: ES 203 021; R&TTE Directive 1999/5/EC (Annex II) with CE Marking (Europe); FCC Part 68; Industry Canada CS03; NOM-151-SCTI-1999 (Mexico); PTC-200 (New Zealand); other Telecom approvals as required by individual countries
Scan
Scan technology
CIS
Scan speed (normal)
Up to 11 ppm
Scan resolution, hardware
Up to 300 x 300 dpi (color and mono, ADF), Up to 600 x 600 dpi (color, flatbed), Up to 1200 x 1200 dpi (mono, flatbed)
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Minimum ADF scan size (metric)
148.5 x 210 mm
Minimum ADF scan size (U.S. standard)
5.9 x 8.3 in
Maximum ADF scan size (metric)
215.9 x 297 mm
Maximum ADF scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
Security
Security management
Password-protected network embedded Web server; enable/disable network ports; SNMPv1 community password change
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8
Minimum system requirements for Macintosh
Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks): 1 GB available hard disk space, Internet required, USB
Compatible network operating systems
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks), v10.8 (Mountain Lion): 1 GB available hard disk space, Internet required, USB. Linux (For more information, see http://hplipopensource.com/hplip-web/index.html).
One-year limited warranty
Country: Flag Bulgaria
