Product Specifications for the HP LaserJet Pro M104w Printer (G3Q37A)
Model name
G3Q37A
What's included and accessories
What's in the box
HP LaserJet Pro M104w printer; HP Black LaserJet toner cartridge; HP LaserJet imaging drum; Getting Started Guide, Setup Poster, Support Flyer; Warranty Guide Flyer, errata in some countries; Printer documentation and software on CD-ROM; Software drivers and documentation on CD-ROMs; CDs containing software and electronic documentation; Power cord; USB cable
Connectivity
Ports
1 Hi-Speed USB 2.0; Wireless
Wireless capability
Standard (Wi-Fi 802.11b/g/n)
Environmental
Acoustic power emissions
6.5 dB
Operating humidity range
30 to 70% RH
Storage humidity
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25º C
Recommended operating temperature range (Fahrenheit)
63.5 to 77º F
Storage temperature range (Celsius)
-20 to 60º C
Storage temperature range (Fahrenheit)
-4 to 140º F
Environmental specifications
Mercury free
Memory
128 MB
Mobile printing capability
Mobile printing services
Apple AirPrint; HP ePrint; Google Cloud Print 2.0; Mopria-certified; Wi-Fi Direct
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/ DHCP/ AutoIP; WINS; SNMP v 1/2/3; HTTP/HTTPS
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; B5 (JIS)
Media sizes supported (U.S. standard)
Letter; Legal; Executive; 8.5 x 13 in; envelopes
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Paper (laser, plain, photo, rough, vellum), envelopes, labels, cardstock, postcards
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
364.7 x 466.6 x 332.4 mm
Maximum dimensions (W x D x H, U.S. standard)
14.4 x 18.4 x 13.1 in
Weight (metric)
4.7 kg
Weight (U.S. standard)
10.4 lb
Power
Energy savings feature technology
HP Auto-on/Auto-off technology
Internal
Power supply
110-volt input voltage: 110 to 127 VAC (+/- 10%), 60 Hz/50 Hz, 4.6 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 60 Hz/, 2.7 A
Power consumption
380 watts (active printing), 1.7 watts (ready), 0.5 watts (sleep), 0.5 watts (Auto Off/Wake on USB, enabled at shipment)
Print cartridges
Number of print cartridges
1 Black
Replacement cartridges
HP 18A Original Black LaserJet Toner Cartridge, CF218A; HP 19A Original LaserJet Imaging Drum, CF219A
Printing specifications
Print technology
LaserJet
Duplex printing
Manual duplex
Print resolution (best)
Up to 600 x 600 dpi, HP FastRes 1200 (1200 dpi quality)
Monthly duty cycle
Up to 10,000 pages
Print languages
PCLmS, URF, PWG
Printer smart software features
HP ePrint, Apple AirPrint, Instant-on Technology, HP Auto-On/Auto-Off, JetIntelligence cartridges
Regulatory specifications
Regulatory model number
SHNGC-1500-01
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/EN60950-1:2006 +A11:2009 +A1:2010+A12:2011+A2:2013; IEC 60825-1:2007 / EN 60825-1:2007 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 - Class B, EN 61000-3-2:2006 +A1:2009 +A2:2009, EN 61000-3-3:2013, EN 55024:2010, FCC Title 47 CFR, Part 15 Class B / ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Security
Security management
Password-protected network Embedded Web Server; enable/disable network ports; SNMPv1 community password change
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8
Minimum system requirements for Macintosh
Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks): 1 GB available hard disk space, Internet required, USB
Compatible network operating systems
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8; Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Apple OS X v10.11 (El Capitan), v10.10 (Yosemite), v10.9 (Mavericks): 1 GB available hard disk space, Internet required, USB. Linux (For more information, see http://hplipopensource.com/hplip-web/index.html).
One-year limited warranty
