Document ID: c05226693
Version: 1
HP X360 310 G2 Convertible PCs - Computer Performance Is Slow After Resuming From Critical Hibernation
Release date : 04-Aug-2016
Last updated : 04-Aug-2016
DESCRIPTION
After the computer resumes from critical hibernation, in which the computer resumes from sleep mode and is transitioned to hibernation mode triggered by a critical low battery level, the performance is slow. The CPU (Central Processing Unit) performance is consistently reports low numbers. (0.08 GHz ,0.13 GHz 0.14 GHz, etc.) This issue may occur on Windows 8.1 and Windows 10 images.
SCOPE
The information in this document applies to the following:
Computers:
  • HP x360 310 G2 Convertible PC
Operating Systems:
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 8.1 Pro (64-bit)
RESOLUTION
To resolve this issue, download and install the following SoftPaq to update the BIOS:
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update (Intel Processors)
Version: F.43
Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/drivers.
Hardware platforms affected : HP x360 310 G2 Convertible PC
Support Communication Cross Reference ID : IA05226693
