    Windows 11 Upgrade Guide
HP Pavilion 15-au014tx Product Specifications
W6T68PA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo; WiDi
1 HDMI; 1 headphone/microphone combo; 2 USB 3.0 (1 HP USB Boost); 1 USB 2.0; 1 RJ-45
38.3 x 24.3 x 2.25 cm
2 kg
65 W AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY
HP 3D DriveGuard; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
