Document ID: c05212009
Version: 1
Advisory: HP Chromebook 11 G4, Chromebook 11-2200 - The Touchpad Does Not Work
Release date : 26-Jul-2016
Last updated : 26-Jul-2016
DESCRIPTION
If you insert a USB recovery image before the new computer reaches the Google login screen, the touchpad may not work on a new computer.
This occurs because the touchpad firmware is updating during the initial startup of a new computer and inserting the USB recovery drive can interrupt the process and disable the touchpad.
SCOPE
Systems:
  • HP Chromebook 11 G4
  • HP Chromebook 11-2200
Operating System:
  • Google Chrome
RESOLUTION
To resolve the issue, update the Chrome OS to Stable Channel update 51.0.2704.106 (Platform version: 8172.62.0) or later.
For further information see:
Hardware platforms affected : HP Chromebook 11 G4, HP Chromebook 11-2200
Support Communication Cross Reference ID : IA05212009
