    Looking for Site Help?
HP DeskJet GT 5810, 5820 Printers - Important Setup and Use Checklist
This document is for HP DeskJet GT 5810 and 5820 printers.
Verify the information in this table when setting up and using your printer.
DO confirm ink is completely filled in all tanks BEFORE inserting the printheads.
DO confirm transportation lock is OPEN (dial points up) BEFORE inserting the printheads.
DO close the blue printhead latch AFTER inserting the printheads and ALWAYS keep it closed.
DO press and hold the RESUME button for 3 seconds when a blinking 'P' displays on the control panel to start the alignment and ink priming process. The ink priming process is required to fill the ink tubes.
You can print or copy immediately after priming has started. You may also restart or power down the printer, if necessary, during the priming process. Priming resumes automatically once power is restored
DO NOT open the blue printhead latch for ANY REASON after setup. The latch should only be opened when replacing printheads.
If print problems occur and you suspect the print heads are at fault, contact HP support.
DO NOT close the transportation lock unless you are MOVING the unit. OPEN the transportation lock immediately after moving the printer.
Country: Flag Bulgaria
