HP PCs - Using a Pen with Windows Ink Workspace (Windows 10)
This document is for HP computers with Windows 10.
The Windows Ink Workspace allows you to launch the Sticky Notes, Sketch Pad, and Snip & Sketch apps in Windows and integrates with Cortana.
You can also use Windows Ink Workspace with a mouse, or a keyboard. The methods supported by apps within Windows Ink Workspace vary.
To open Windows Ink Workspace, click the Windows Ink Workspace icon on the taskbar.
If the icon does not display on the taskbar, right-click an empty area on the taskbar to access the Toolbars menu, and then select Show Windows Ink Workspace button.
The Toolbars menu with Show Windows Ink Workspace highlighted
