    Apache Log4j Update
HP Pavilion x360 11-u022tu Product Specifications
X0T08PA
Intel® Pentium® N3710 (1.6 GHz, up to 2.56 GHz, 2 MB cache, 4 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 405
  • Integrated
500 GB 5400 rpm SATA
11.6" diagonal HD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0
30.6 x 20.8 x 1.93 cm
1.33 kg
45 W AC power adapter
2-cell, 34.6 WH Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
