HP Notebook - 14-am079tu Product Specifications
X5Q16PA
Intel® Celeron® N3060 (1.6 GHz, up to 2.48 GHz, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
  • Intel® HD Graphics 400
  • Integrated
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
1 VGA; 1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
34.54 x 24.15 x 2.39 cm
Starting at 1.94 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
