HP Notebook - 14-am029tu Product Specifications
X0T45PA
Intel® Core™ i3-5005U (2 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
  • Intel HD Graphics 5500
  • Integrated
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 VGA; 1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
34.54 x 24.15 x 2.39 cm
Starting at 1.94 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP ePrint; HP Recovery Manager; HP Support Assistant
