    Apache Log4j Update
HP Notebook - 15-ay013nr (ENERGY STAR) Product Specifications
W2M74UA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 520 (up to 4.04 GB)
128 GB M.2 SSD
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11ac (1x1) and Bluetooth® 4.0 combo
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.4 x 25.5 x 2.37 cm
2.1 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP ePrint; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink Power Media Player; CyberLink PowerDirector; TripAdvisor
