HP V197 18.5-inch Monitor - Specifications
Panel
Specification
Model
V5J61AA
Type
TN (twisted nematic) LED backlit LCD
46.9 cm (18.5 in) widescreen
Panel active area (W x H)
40.98 x 23.04 cm (16.13 x 9.07 in)
Aspect ratio
16:9
Resolution
1366 x 768 at 60Hz
Viewing angle (typical)
Up to 90° horizontal/65° vertical
Brightness
200 cd/m2
Contrast ratio (typical)
600:1 Static
5,000,000:1 Dynamic (DCR)
Response times
5 ms typical (on/off)
Pixel pitch
0.3 x 0.3 mm (.01 x .01 in)
Pixels per inch (PPI)
84.7
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
User controls
Specification
Buttons or switches
Menu, Minus ("-"), Plus ("+"), OK, Power
User programmable modes
20
Languages
English, French, German, Italian, Japanese, Netherlands, Portuguese, Simplified Chinese, Spanish, Traditional Chinese
On screen display (OSD) user controls
Brightness, Contrast, Color, Image Control, OSD control, Management, Language, Information, Factory Reset
Signal interface/performance
Specification
Horizontal frequency
30 - 80 kHz
Vertical frequency
50 – 60 Hz
Native resolution
1366 x 768 at 60Hz
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1366 x 768 at 60 Hz
Maximum pixel clock speed
110 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input/output connectors
(1) VGA
(1) DVI-D
USB
N/A
Cables included
(1) VGA 1.5 m (4.9 ft)
Audio
N/A
Power
Specification
Power supply
Internal
Input power
100-240 VAC 50/60 Hz
Maximum power
17 W
Typical power
15 W
Sleep power
0.5 W
Power cable length
1.5 m (4.9 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand: 44.14 x 21.81 x 33.86 cm (17.38 x 8.59 x 13.33 in)
Unpacked without stand (head only): 44.14 x 4.54 x 27.77 cm (17.38 x 1.79 x 10.94 in)
Packaged: 52.2 x 10 x 34.6 cm (20.55 x 3.94 x 13.62 in)
Head only: 2.4 kg (5.30 lb)
Unpacked: 2.7 kg (6.0 lb)
Packaged: 3.8 kg (8.4 lb)
Ergonomic features
Specification
Detachable stand
Yes, ships detached
Height adjustment
N/A
Tilt range
-5° to +22° vertical
Swivel
N/A
Pivot
N/A
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,400 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
Arsenic-free display glass
Yes
Low halogen
No
Mercury-free display backlighting
Yes
