    We are upgrading our website
Document ID: c05093013
Version: 1
BIOS Update for RP5 Retail System Model 5810
Release date : 20-Apr-2016
Last updated : 13-Jun-2016
DETAILS OF CHANGE
BIOS maintenance update – major changes from 2.26 to 2.27:
  • Added new Security Updates
  • Fixed the ability to update the BIOS using the Network when the Setup Password is enabled
  • Fixed the BiosConfigUtility to Enable or Disable the HDD in the UEFI Boot Sources
  • Fixed the “Allow Wake-On-LAN” to disable “Fast Boot” to allow “Remote Wakeup Boot Source” to execute
  • Fixed the PCI Slot Security “Enable/Disable” settings not restoring after “Sleep” (S3) state
  • This version of the BIOS may not be flashed back to prior versions
BIOS maintenance update – major changes from 2.27 to 2.29:
  • Fixed issue with certain high density specialty drives taking too long to spin up and as a result the drive is not found by the system during a cold boot
  • Updated Video BIOS to support 2nd Display Port monitor
COMPONENT VERSION
Changing from 2.26 to 2.29
REASON FOR CHANGE
  • Additional Security Updates
  • Fixed the ability to update BIOS using the Network update with the Setup Password enabled
  • Fixed Wake-On-LAN and PCI Slot Security features
  • Fixed high density drive boot issue
IMPACT OF CHANGE
  • Improves security of the system
  • Allows the BIOS to be updated by the Network process
  • Fixed user settings for customized BIOS
Components affected:
L20 BIOS Family
DATE OF CHANGE
Effective date : 27-Jun-2016
Hardware platforms affected : HP RP5 Retail System Model 5810
