HP ENVY Notebook - 15-ae150tx Product Specifications
V5E24PA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
Intel HM170
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA; 256 GB SSD
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Island-style backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
External Ports
4 USB 3.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.4 x 25.5 x 2.29 cm
Starting at 2.12 kg
90 W AC power adapter
3-cell, 55.5 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Dual speakers with 1 subwoofer
FreeDOS 2.0
