HP OfficeJet Pro 8210 Printers - Ink Cartridge Errors
This document is for the HP OfficeJet Pro 8210, 8216, and 8218 printers.
The printer does not print, and one of the following error messages displays on the printer control panel:
  • Cartridge Problem
  • Incompatible Cartridge
  • Missing Cartridge
You must install the SETUP ink cartridges that came with your printer during the initial printer setup or an ink cartridge error occurs.
Step 1: Make sure the ink cartridges are compatible
HP recommends that you use genuine HP ink cartridges. HP cannot guarantee the quality or reliability of non-HP ink cartridges or refilled HP ink cartridges. Make sure you are using the correct HP ink cartridge for your printer.
This printer is enabled with dynamic security. It is intended to be used only with cartridges with an original HP chip. Ink cartridges using a non-HP chip may not work, and those that work today may not work in the future. For more information see Dynamic Security Enabled Printers.
To purchase ink cartridges through other retailers, make note of the following ink cartridges that work with your printer.
Ink cartridge description
United States and Canada
Europe, Africa, CIS, and Middle East
Latin America
Asia Pacific and Japan
Black ink cartridge
HP 952 Black
HP 952XL Black
HP 956XL Black
HP 953 Black
HP 953XL Black
HP 957XL Black
HP 954 Black
HP 954XL Black
HP 958XL Black
HP 955 Black
HP 955XL Black
HP 959XL Black
Cyan ink cartridge
HP 952 Cyan
HP 952XL Cyan
HP 953 Cyan
HP 953XL Cyan
HP 954 Cyan
HP 954XL Cyan
HP 955 Cyan
HP 955XL Cyan
Magenta ink cartridge
HP 952 Magenta
HP 952XL Magenta
HP 953 Magenta
HP 953XL Magenta
HP 954 Magenta
HP 954XL Magenta
HP 955 Magenta
HP 955XL Magenta
Yellow ink cartridge
HP 952 Yellow
HP 952XL Yellow
HP 953 Yellow
HP 953XL Yellow
HP 954 Yellow
HP 954XL Yellow
HP 955 Yellow
HP 955XL Yellow
If installing genuine HP ink cartridges did not resolve the issue, continue to the next step.
Step 2: Make sure the ink cartridges and carriage are correctly installed
The printer might display an error if the ink cartridges are not correctly installed or the carriage is not secured to the printhead.
  1. Turn on the printer.
  2. Open the ink cartridge access door.
    Figure : Opening the ink cartridge access door
  3. Wait until the carriage is idle and silent before you continue.
  4. Push in on the front of one of the ink cartridges to release it, and then pull the ink cartridge toward you to remove it.
    Figure : Removing the ink cartridge
  5. Reinsert the ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
    Figure : Reinserting the ink cartridge
  6. Repeat these steps for the other ink cartridges.
  7. Make sure each ink cartridge is not sticking out farther than the other ink cartridges. If an ink cartridge is sticking out, push it until it snaps into place.
  8. Make sure the carriage latch is secure. Press down on the carriage latch until it snaps into place.
    Figure : Pressing down on the carriage latch
    Image: Carriage latch is down
  9. Close the ink cartridge access door.
  10. Check the control panel for any error messages.
If the issue persists, continue to the next step.
Step 3: Clean the ink cartridge contacts
Clean the ink cartridge contacts to remove debris that might be preventing an electrical connection.
Clean the ink cartridges one at a time. Do not leave an ink cartridge outside of the printer for more than 10 minutes. Also, never turn off the printer when an ink cartridge is removed from its slot. Leaving ink cartridge slots empty might cause damage to the ink system.
  1. Find a clean, lint-free cloth (eyeglass wipes or coffee filters work well) that you can use to clean the ink cartridge contacts.
    Image: Lift the ink cartridge cover
  4. Push in on the front of the problem ink cartridge to release it, and then pull the ink cartridge toward you to remove it from its slot.
  5. With a clean, lint-free cloth (eyeglass wipes or coffee filters work well), wipe the copper-colored contact on the ink cartridge.
    Figure : Example of copper-colored contact
  6. Carefully reinsert the ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
  7. Repeat these steps for other ink cartridges.
  8. Close the ink cartridge access door.
  9. Check the control panel for any error messages.
Step 4: Remove and reinsert the ink cartridges again
Repeat the steps you performed earlier in this document to remove and reinsert the ink cartridges.
Step 5: Clean the ink cartridge contacts again
Cleaning the problem ink cartridge contacts a second time can help resolve the issue. Repeat the steps that you performed earlier in this document to clean the contacts.
Step 6: Reset the printer
Resetting the printer can reset the connection with the ink cartridge and clear any error messages.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.
  9. Wait until the printer is idle and silent before you proceed.
Step 7: Replace the problem ink cartridge
The error message might indicate a specific ink cartridge caused the error. Replace the problem ink cartridge.
If you have a defective cartridge or printhead, it might be under warranty. To check the warranty on your ink or toner supplies, go to Printer and Page Yield Overview, and then review the limited warranty information for your supplies.
  4. Push in on the front of the ink cartridge to release it, and then pull the ink cartridge toward you to remove it.
  5. Remove the replacement ink cartridge from its package.
  6. Carefully insert the new ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
  7. Repeat these steps for the other ink cartridges.
  8. Make sure each ink cartridge is not sticking out farther than the other ink cartridges. If an ink cartridge is sticking out, push it until it snaps into place.
Step 8: Service the printer
If the previous steps did not resolve the ink cartridge error, service the printer.
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
