HP OfficeJet 200 Mobile Printers - Ink Cartridge Errors
This document is for the HP OfficeJet 200, 200c, 202, and 202c Mobile Printers.
After you install an ink cartridge, one of the following error messages displays on the printer control panel:
  • Cartridge Problem
  • Incompatible Cartridge
  • Cartridges Missing
Step 1: Make sure the cartridges are compatible
An ink cartridge error displays if the wrong ink cartridge is installed.
To purchase ink cartridges through other retailers, make note of the following ink cartridges that work with your printer.
Ink Cartridge Description
Worldwide
Black ink cartridge
HP 62 Black
HP 62XL Black
Color ink cartridge
HP 62 Tri-color
HP 62XL Tri-color
Ink cartridge description
Europe, Middle East, and Africa
Black ink cartridge
HP 651 Black
Color ink cartridge
HP 651 Tri-color
If installing genuine HP ink cartridges did not resolve the issue, continue to the next step.
Step 2: Remove, inspect, and then reseat the ink cartridges
The printer might display an error if the ink cartridges are not correctly installed.
  1. Turn on the printer.
  2. Open the ink cartridge access door.
    Figure : Opening the ink cartridge access door
    Image: Lift the ink cartridge cover
  3. Wait until the carriage is idle and silent before you continue.
  4. To release the ink cartridge, lift the ink cartridge latch.
    Figure : Opening the ink cartridge latch
    Image: Release the ink cartridge latch
  5. Remove the ink cartridge from its slot.
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or nozzles
    Image: Do not touch the contacts or nozzles
  6. Inspect for and remove the any protective tape from the contacts.
    Do not try to remove the copper electrical strip.
    Figure : Removing the plastic tape
    Image: Remove the plastic tape
  7. Insert the ink cartridge into its slot, and then press the ink cartridge forward until it latches into place.
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Figure : Closing the ink cartridge latch
    Image: Making sure the ink cartridge is snapped into place
  8. Repeat these steps for the other ink cartridge, if necessary
  9. Close the ink cartridge access door.
    Figure : Closing the ink cartridge access door
    Image: Closing the ink cartridge access door
Try to print again. If these steps did not resolve the issue, continue to the next step.
Step 3: Clean the electrical contacts
If the ink cartridge or carriage contacts are dirty, the printer might display an ink cartridge error. Unplug any cords, remove the battery and ink cartridges, and then clean the electrical contacts on ink cartridges and print carriage.
  1. Gather the following materials:
    • A clean, lint-free cloth
    • A clean, dry cotton swab
    • Distilled or bottled water
      Do not use platen cleaners, tap water, or alcohol to clean the contacts. These can damage the ink cartridge or the printer.
  4. Disconnect any cords connected to the printer, such as the power cord and USB cable.
  5. Remove the battery cover. Push the battery cover tab to the right, and then pull the cover toward you.
    Figure : Removing the battery cover
    Image: Removing the battery cover
  6. Push up on the battery latch, and then slide the battery out of its slot.
  7. To release the ink cartridge, lift the ink cartridge latch.
  8. Remove the ink cartridge from its slot.
    Do not remove both ink cartridges at the same time. Remove and clean each ink cartridge one at a time. Do not leave an ink cartridge outside the printer for more than 30 minutes.
  9. Hold the ink cartridge by its sides.
    Figure : Holding the ink cartridge by its sides
    Image:  Hold the ink cartridge by its sides
  10. Inspect the contacts for ink and debris buildup.
  11. Gently wipe the contacts with a dry swab or lint-free cloth until no ink or debris remains on the contacts.
    Be careful to wipe only the contacts. Do not smear any ink or debris elsewhere on the ink cartridge.
    Figure : Cleaning the contacts
    Image: Clean the contacts
  12. Lightly dampen a clean foam-rubber swab or lint-free cloth into distilled water, and then clean the copper-colored contacts.
  13. Dip another clean foam-rubber swab or lint-free cloth into distilled water, squeeze out excess water, and then clean the electrical contacts in the carriage, located inside the printer.
    Figure : Example of carriage contacts
    Image: The carriage contacts
  14. Wait 10 minutes for the ink cartridge and carriage contacts to dry before you continue.
  15. Insert the ink cartridge into its slot, and then press the ink cartridge forward until it latches into place.
  16. Repeat these steps to clean and reinsert the other ink cartridge.
  17. Close the ink cartridge access door.
  18. Slide the battery into its slot, and then press the left side of the battery until it clicks into place.
    Figure : Installing the battery
    Pushing the left edge of the battery cover until it clicks into place
  19. Slide the battery cover into its slot, and then press the left side of the cover until it clicks into place.
    Figure : Installing the battery cover
  20. Reconnect the power cord or USB cable to the printer, if needed.
  21. Turn on the printer.
Step 4: Remove and then reinsert the ink cartridges again
Repeat the steps you performed earlier in this document to remove and reinsert the ink cartridges.
Make sure the ink cartridges are latched firmly into place.
Step 5: Clean the ink cartridge and carriage contacts again
Cleaning the ink cartridge and carriage contacts a second time can help resolve the issue. Repeat the steps that you performed earlier in this document to clean the contacts.
Step 6: Reset the printer
Resetting the printer can resolve an ink cartridge error.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.
  9. Wait until the printer is idle and silent before you proceed.
Step 7: Install a new ink cartridge
Replace the ink cartridge indicated in the error message with a new genuine HP ink cartridge.
If you have a defective cartridge or printhead, it might be under warranty. To check the warranty on your ink or toner supplies, go to hp.com/go/learnaboutsupplies, and then review the limited warranty information for your supplies.
  2. Make sure plain white paper is loaded in the input tray.
  3. Open the ink cartridge access door.
  4. Wait until the carriage is idle and silent before you continue.
  5. To release the ink cartridge, lift the ink cartridge latch.
  6. Remove the ink cartridge from its slot.
  7. Remove the replacement ink cartridge from its package. Be careful to only touch the black plastic on the ink cartridge.
    Figure : Removing the ink cartridge from its package
    Image: Removing the ink cartridge from its package
  8. Remove the plastic tape from the ink cartridge.
    Image: Removing the plastic tape
  9. Insert the new ink cartridge into its slot, and then press the ink cartridge forward until it latches into place.
  10. Repeat these steps for the other ink cartridge, if necessary
  11. Close the ink cartridge access door.
  12. The printer automatically aligns any newly installed ink cartridge.
    If the printer did not automatically align the ink cartridges, align the ink cartridges through the printer control panel:
    1. From the home screen on the printer control panel, use the arrow buttons to select Setup, and then press OK.
    2. Press the down arrow to select Tools, and then press OK.
    3. Press the down arrow to select Align Printer, and then press OK.
      Aligning... displays on the control panel. The printer might beep or make mechanical noises, and then the printer prints an alignment page.
Step 8: Service the printer
If the previous steps did not resolve the ink cartridge error, service the printer.
