    Fix HP Printer issue on macOS
HP EliteBook 1040 G3 Notebook PC - Specifications
Product image
Feature
Preinstalled
Windows 10 Pro 64
Windows 7 Professional 64 (Available through downgrade rights from Windows 10 Pro 64)
FreeDOS 2.0
Web-only support
Windows 10 Enterprise 64
Windows 8.1 Enterprise 64
Windows 7 Professional 32
Windows 7 Enterprise 64
Windows 7 Enterprise 32
Processors
Feature
Intel Core i7-6600U with Intel HD Graphics 520
2.6 GHz, up to 3.4 GHz with Intel Turbo Boost Technology
4 MB cache
2 cores
Intel Core i7-6500U with Intel HD Graphics 520
2.5 GHz, up to 3.1 GHz with Intel Turbo Boost Technology
4 MB cache
2 cores
Intel Core i5-6300U with Intel HD Graphics 520
2.4 GHz, up to 3 GHz with Intel Turbo Boost Technology
3 MB cache
2 cores
Intel Core i5-6200U with Intel HD Graphics 520
2.3 GHz, up to 2.8 GHz with Intel Turbo Boost Technology
3 MB cache
2 cores
Graphics
Feature
Integrated
Feature
Internal
Non-touch
14 in diagonal LED-backlit FHD+ Anti-glare SVA (1920 x 1080), 300 nits
14 in diagonal LED-backlit FHD+ Anti-glare SVA (1920 x 1080), 300 nits with WWAN
14 in diagonal LED-backlit FHD+ Anti-glare SVA (1920 x 1080), 300 nits with camera
14 in diagonal LED-backlit FHD+ Anti-glare SVA (1920 x 1080), 300 nits with camera and WWAN
14 in diagonal LED-backlit QHD UWVA (2560 x 1440), 340 nits
14 in diagonal LED-backlit QHD UWVA (2560 x 1440), 340 nits with WWAN
14 in diagonal LED-backlit QHD UWVA (2560 x 1440), 340 nits with camera
14 in diagonal LED-backlit QHD UWVA (2560 x 1440), 340 nits with camera and WWAN
Touch
External
Up to 32-bit pixel depth
HDMI 1.4
Storage and drives
Feature
M.2 (NGFF) Solid State Drives
128 GB SATA-3 TLC
180 GB SATA-3 MLC
180 GB SATA-3 MLC (Opal 2)
240 GB SATA-3 MLC
256 GB PCIe-3x4 DS NVMe
256 GB SATA-3 MLC (Opal 2)
256 GB SATA-3 TLC
512 GB SATA-3 TLC
Memory
Feature
Standard
DDR4 PC4-2133 (Transfer rates up to 2133 MT/s)
Memory soldered down
Supports Dual Channel Memory
8192 MB total system memory (512 MB x 16 MB)
16384 MB total system memory (512 MB x 16 MB x 2)
Maximum
16 GB total system
Networking/communication
Feature
Broadband wireless (WWAN)
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP 3110 HSPA+ Mobile Broadband Module
Wireless LAN (WLAN)
Intel 802.11a/b/g/n/ac (2 x 2) and Bluetooth 4.2 Combo
Communications
Intel I218LM (Jacksonville-LM) 10/100/1000 Ethernet, with iAMT
Optional Near Field Communication (NFC) with Secure Element
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
2 integrated stereo speakers
Integrated dual-array microphone
Button for speaker mute; function keys for volume up and down
Headphone/Microphone combo port
Intel Smart Sound Technology (Windows 8.1 and Windows 10)
720p HD webcam (optional)
HD format (widescreen)
Supports videoconferencing and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Keyboard
Feature
Keyboard
Spill-resistant with drain
Backlit
HP Dura Keys
Touchpad
ClickPad
Glass with chemical etched surface
Taps enabled as default
Gestures enabled by default
2 finger scrolling
2 finger zoom (pinch)
Buttons and function keys
F1 - Sleep
F2 - Blank
F3 - Backlit
F4 - Display switch
F5 - Brightness down
F6 - Brightness up
F7 - Blank
F8 - Volume down
F9 - Volume up
F10 - Mic mute
F11 - Blank
F12 - Num lock
Software and security
Feature
BIOS
HP BIOSphere
HP Sure Start with Dynamic Protection
HP DriveLock
HP Automatic DriveLock
HP BIOS protection
HP SpareKey
BIOS Update via network
Master Boot Record Security
Power-on Authentication
Pre-boot Security
Secure Erase
Hybrid Boot
Measured Boot
Secure Boot
Pre-boot Authentication
Multimedia
Cyberlink PowerDVD, BD
Cyberlink YouCam BE (Windows 7 only)
Communication
HP GPS and Location (Windows 7 only)
HP Connection Manager with support for HP Mobile Connect Pro (Windows 7 only)
HP Mobile Connect Pro (Windows 8.1 and Windows 10 only)
Intel Wireless Display (WiDi) Software for Windows
Native Miracast Support
HP Value Add software
HP 3D DriveGuard
HP ePrint driver
HP Hotkey Support
HP Recovery Manager
HP Recovery Disc Creator
HP Registration App (Windows 8.1 only)
HP Support Assistant
HP Noise Reduction Software
3rd party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing Search
Skype
Manageability
HP Driver Packs
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP Client Catalog
HP CIK for Microsoft SCCM
LANDESK Management
HP Image Assistant
Client security software
HP Security Manager (including Credential Manager and Password Manager)
HP Drive Lock
HP Fingerprint Sensor
HP Password Manager
Absolute Persistence Module
Power On Authentication
Microsoft Security Essentials
Microsoft Defender
Security
Trusted Platform Module (TPM) 1.2 Embedded Security Chip (Common Criteria EAL4+ Certified). Field upgradeable to TPM 2.0
Security lock slot (cable not included)
Fingerprint Reader
Integrated Smart Card Reader
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Feature
Power supply
45W 2-prong AC Adapter
45W Smart AC Adapter
65W Smart EM AC Adapter
65W Slim Travel AC Adapter
Power cord included: 1 m (3.2 ft)
Optional power cord: 1.8 m (5.9 ft)
Primary battery
HP 6-Cell (45.6 Whr) polymer long life battery
Weight and dimensions
Feature
Non-touch
1.43 kg (3.15 lb)
Touch
1.54 kg (3.40 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
Non-touch
33.7 x 23.45 x 1.58 cm (13.27 x 9.23 x 0.62 in) (front)
Touch
33.7 x 23.45 x 1.65 cm (13.27 x 9.23 x 0.65 in) (front)
Ports
Feature
Ports
USB 3.0 charging port - 2
USB-Type C charging port (15 W) - 1
Docking connector -1
HDMI 1.4 - 1
Headphone / microphone combo - 1
Multi-Pin AC Port (4.5 mm) - 1
