HP Stereo USB Headset - Specifications
Product specifications
Feature
Model
T1A67AA
Dimensions (W x H x D)
146 x 164 x 58 mm (5.75 x 6.46 x 2.28 in)
110 g (3.88 oz)
Speaker driver
Driver: 30 mm diameter
Sensitivity: 111 dB
Frequency response: 20k Hz
Distortion: max 3%
Audio power output RMS: 5 mW
Impedance: 32Q
Microphone
Unit: 9.7 mm diameter
Type: noise cancelling
Sensitivity: -40 dBV/Pa
SNR: less than 60 dB
Max input SPL: 110 dB
Impedance: 680 Ohm
Operating voltage: 3 V
Connector
USB type A, IC: C-media HS100B
Color
Black
Temperature
Operating: – 10˚ to 40˚ C
Non-operating: – 20˚ to 70˚ C
Compatibility
USB Type A female connector
Regulations
CE, CB, FCC, UL, KCC, CCC
Kit contents
Headset, QSG, Warranty card, Product Notice card
