HP Pavilion Notebook - 14-ab037tx Product Specifications
M7R31PA
Intel® Core™ i5-5200U with Intel HD Graphics 5500 (2.2 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce 940M (2 GB DDR3L dedicated)
Hard Drive
2 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
14" diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Island-style Keyboard
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible); WiDi
External Ports
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
34.54 x 24.25 x 2.5 cm
Starting at 1.96 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
B&O PLAY with 2 speakers
Windows 8.1 64
Pre-installed software
CyberLink PowerDVD; CyberLink YouCam; CyberLink Media Suite; Cyberlink Power2Go; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; User Guide documentation; iPASS; Skype; Evernote; Dropbox
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard; HP Connected Photo; HP Connected Drive; HP SimplePass
Buy Office
