HP ProBook 655 G2 Notebook PC - Specifications
Feature
Preinstalled
Windows 10 Pro 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 7 Professional 64 (Available through downgrade rights from Windows 10 Pro 64)
Windows 7 Professional 32 (Available through downgrade rights from Windows 10 Pro 64)
Ubuntu Linux
Ubuntu Kylin Linux
FreeDOS 2.0
Web-only support
Windows 10 Enterprise 64
Windows 8.1 Enterprise 64
Windows 7 Enterprise 64
Windows 7 Enterprise 32
Graphics
Feature
Integrated
Radeon R5
Radeon R6
Feature
Internal
Non-touch
  • 15.6 in diagonal LED backlight HD anti-glare (1366 x 768)
  • 15.6 in diagonal LED backlight HD anti-glare (1366 x 768) with camera
  • 15.6 in diagonal LED backlight HD anti-glare (1366 x 768) with WWAN
  • 15.6 in diagonal LED backlight HD anti-glare (1366 x 768) with camera and with WWAN
  • 15.6 in diagonal LED backlight FHD anti-glare (1920 x 1080)
  • 15.6 in diagonal LED backlight FHD anti-glare (1920 x 1080) with camera
  • 15.6 in diagonal LED backlight FHD anti-glare (1920 x 1080) with WWAN
  • 15.6 in diagonal LED backlight FHD anti-glare (1920 x 1080) with camera & WWAN
Touch
  • 15.6 in diagonal LED backlight FHD (1920 x 1080) with camera and with WWAN
External
Up to 32-bit pixel depth
VGA: Port supports resolutions up to 1920 x 1200 external resolution at 60 Hz
DisplayPort 1.2: Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
Storage and drives
Feature
Hard drives
Supports SATA 3, 7 mm
2.5 in hard drives
500 GB 7200 rpm
500 GB 7200 rpm self encrypting drive (Opal 2)
500 GB 5400 rpm self encrypting drive (Opal 2)
1 TB 5400 rpm
500 GB hybrid
M.2 (NGFF) solid state drive
128 GB SATA-3 TLC
180 GB SATA-3 MLC
180 GB SATA-3 MLC (Opal 2)
240 GB SATA-3 MLC
256 GB PCIe-3x4 DS NVMe
256 GB SATA-3 MLC (Opal 2)
256 GB SATA-3 TLC
512 GB SATA-3 TLC
Optical drives (fixed 9.5 mm SATA)
DVD-ROM drive
DVD+/-RW SuperMulti DL
Blu-ray ROM DVD+/-RW SuperMulti DL
Weight saver
Memory
Feature
Standard
DDR4-2133 SDRAM (Transfer rates up to 2133 MT/s)
Two SODIMM slots supporting dual-channel memory
4096 MB total system memory (4096 MB x 1)
8192 MB total system memory (4096 MB x 2)
8192 MB total system memory (8192 MB x 1)
12288 MB total system memory (8192 MB + 4096 MB)
16384 MB total system memory (8192 MB x 2)
Maximum
Up to 16384 MB with optional 8192 MB SODIMMs in slots 1 and 2
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Networking/communication
Feature
Broadband wireless (WWAN)
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP hs3110 HSPA+ Mobile Broadband Module
Wireless LAN (WLAN)
Options via Minicard
Intel 802.11a/b/g/n/ac (2x2) and Bluetooth 4.1 Combo
Intel 802.11a/b/g/n (2x2) and Bluetooth 4.0 Combo
Broadcom 802.11a/b/g/n (2x2) and Bluetooth 4.0 Combo
Broadcom 802.11b/g/n (1x1) Wi-Fi and Bluetooth 4.0 Combo
Realtek 802.11b/g/n (1x1) Wi-Fi
Personal area network (WPAN Bluetooth)
Bluetooth 4.0 supported via all combo cards (except for Intel 802.11 ac and Intel 802.11 a/b/g/Non-vPro)
Bluetooth 4.1 supported via (Intel 802.11 ac and Intel 802.11 a/b/g/n Non-vPro only)
Near field communication (NFC) optional
HP Module with NXP NFC Controller NPC100
Communications
Intel I219V 10/100/1000 Ethernet
Audio/multimedia
Feature
Audio
HD Audio with DTS Sound+
(2) Integrated stereo speakers
Integrated digital microphone (Dual-microphone array when equipped with optional webcam)
Function keys for microphone mute, volume up, volume down
Stereo headphone/line out
Stereo microphone in
720p HD webcam (optional)
HD format (widescreen)
Supports videoconferencing (non-HD) and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Skype-ready (subscription required and sold separately)
Keyboard
Feature
HP Advanced keyboard
The HP spill-resistant keyboard is designed using a thin layer of mylar film under the keyboard. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. DuraKeys only available with backlit option.
Touchpad
On/off button
Enabled by default
2 finger scrolling - On
2 finger zoom (pinch ) - On
OSD (enable / disable ) - On
Windows 8 2 finger tap = right click - On
Windows 8 edge swipes – On
Buttons and function keys
F1 - Sleep
F2 - Blank
F3 - Backlit
F4 - Display Switch
F5 - Brightness down
F6 - Brightness up
F7 - Blank
F8 - Volume down
F9 - Volume up
F10 - Mic Mute
F11 - Bank
F12 - Num lock
Software and security
Feature
BIOS
HP DriveLock
HP Automatic DriveLock
HP BIOS protection
HP Disk Sanitizer
HP SpareKey
BIOS update via network
Master Boot Record Security
Power-on Authentication
Pre-boot Security
Secure Erase
Hybrid Boot
Measured Boot
Secure Boot
Absolute Persistence Module
Multimedia
Cyberlink PowerDVD
Cyberlink Power2Go (optical drive)
Cyberlink YouCam BE (Windows 7 only)
Communication
HP GPS and Location (Windows 7 only)
HP Connection Manager (Windows 7 only)
HP Mobile Connect (Windows 8 only)
HP Wireless Hotspot (Windows 8 only)
Intel WiDi Software
HP Roaming Alert (Windows 8 only)
Intel Wireless Display (Wi-Di) Software for Windows
Intel My WiFi and Wireless Drivers
HP Value Add software
HP 3D DriveGuard (requires Windows)
HP ePrint driver
HP PageLift (HP exclusive)
HP Recovery Manager (Windows 7 only)
HP Recovery Disc Creator (Windows 7 only)
HP Support Assistant
3rd party
Adobe Flash Player
Skype (subscription required and sold separately)
Buy Office
Security hardware
HP Client Security
HP Credential Manager
HP Password Manager
HP Drive Encryption (FIPS 140-2)
HP Device Access Manager with Just In Time Authentication
HP File Sanitizer
HP Spare Key
Integrated Smart Card Reader (FIPS 201)
Security screw for bottom access door
Microsoft Security Essentials (Windows 7)
Microsoft Defender (Windows 8)
TPM 1.2/2.0
HP fingerprint reader
Security lock slot
Integrated smart card reader
Power
Feature
Power supply
HP 45 W Smart AC Adapter (UMA only)
HP 45 W Smart AC Adapter (Only available for Japan and England)
HP 65 W Smart AC Adapter
HP 65 W Smart EM Adapter (only available for Asia, China and India)
Power cord included is 1.8 m (+/- 0.1 m) or 1.0 m (+/- 0.1 m)
Primary battery
HP 3-cell long life prismatic (48 WHr)
Weight and dimensions
Feature
2.31 kg (5.1 lb)
Dimensions (W x D x H)
37.8 x 25.7 x 2.74 cm (14.88 x 10.11 x 1.07 in)
Ports/slots
Feature
Ports
USB-C charging port - 1
USB 3.0 port (1 charging) - 2
RJ-45 / Ethernet - 1
Docking connector -1
Headphone / microphone (combo jack ) - 1
AC port (4.5 mm) - 1
DisplayPort 1.2 - 1
VGA - 1
Slots
SD Media Reader slot (supports SD, SDHC, SDXC)
