HP EliteDisplay E202 20-inch Monitor - Specifications
Panel
Specification
Type
20-inch diagonal w/LED backlight
50.8 cm (20 in)
Panel active area
44.28 x 24.9 cm (17.43 x 9.81 in)
Resolution
1600 x 900 at 60 Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal/178° vertical typical
Brightness
250 cd/m2
Contrast ratio (typical)
1000:1 static; 5,000,000:1 dynamic (DCR)
Response times
7 ms gray to gray
Pixel pitch
0.28 x 0.28 mm
Pixels per inch (PPI)
91 PPI
Backlight lamp life (to half brightness)
40,000 hours minimum
Color gamut
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
User controls
Specification
Buttons or switches
Dynamically adjust depending upon OSD screen selected
User Programmable Modes
Yes, 10
Languages
10 (English, French, German, Italian, Japanese, Dutch, Portuguese, Spanish, Traditional Chinese and Simplified Chinese)
On screen display (OSD) user controls
Brightness, Contrast, Color, Image Control, OSD control, Management, Language, Information, Factory Reset, Input Control, Exit
Signal interface/performance
Specification
Horizontal frequency
30-70 kHz
Vertical frequency
56-75 Hz
Native resolution
1600 x 900 at 60 Hz
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 at 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input/output connectors
VGA - 1
DisplayPort 1.2 - 1
HDMI - 1
HDCP support on DisplayPort and HDMI
USB
USB 2.0 (two downstream and one upstream) - 3
Video cables included
VGA 1.8 m (5.9 ft) - 1
DisplayPort 1.8 m (5.9 ft) - 1
USB cable 1.8 m (5.9 ft) - 1
Audio
N/A
Power
Power supply
Internal
Input power
100 - 220 VAC 50/60 Hz
Maximum power
33 W
Typical power
22 W
Sleep power
0.5 W (standby)
Power cable length
1.9 m (6.2 ft)
Mechanical
Specification
Dimensions (W × D × H)
Unpacked with stand
47.9 x 18.9 x 49.3 cm (18.85 x 7.44 x 19.42 in)
Unpacked without stand
47.9 x 4.95 x 29.68 cm (18.85 x 1.95 x 11.68 in)
Packaged
56.8 x 22.5 x 35 cm (22.36 x 8.86 x 13.78 in)
Head Only
2.8 kg (6.22 lb)
Unpacked
4.8 kg (10.67 lb)
Packaged
6.2 kg (13.78 lb)
Ergonomic features
Specification
Detachable stand
Yes
Height adjustment
150 mm
Tilt range
-5° to + 25° vertical
Swivel
±45°
Pivot
90°
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80%
Non-operating: 5% to 95%, 38.7° C non-condensing
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes
Mercury-free display backlighting
Yes
What's in the box?
Specification
Monitor and accessories
AC power cord 1.9 m (6.2 ft)
VGA cable 1.8 m (5.9 ft)
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
Miscellaneous
Specification
User guide languages
Arabic, Brazilian, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Portuguese, Russian, Slovenian, Spanish, Swedish, Turkish, Traditional Chinese and Simplified Chinese
Warranty languages
Color
Black bezel and rear cover; silver stand
VESA mounting
100 mm VESA mount
Security lock-read
Yes
Country of origin
China
Certification and compliance
TCO Certified Edge, CEL Grade 1, Microsoft WHQL Certification (Windows 10, Windows 8.1 and Windows 7), ENERGY STAR Qualified, EPEAT Gold2,CE, CB, KC, KCC, NOM, PSB, ICE, TUV-S, ISO 9241-307, EAC, UL, CSA, PSB, ISC, CCC, CEL, CECP, SEPA, ISC, VCCI, FCC, BSMI, Vietnam MEPS, Australian-New Zealand MEPS, WEEE
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
Service and warranty
Protected by HP, including a 3 year standard limited warranty. Optional HP Care Pack Services are extended service contracts that extend your protection beyond the standard warranties.
Country: Flag Bulgaria
