HP Pavilion Notebook - 15-ab222tu Product Specifications
P3V34PA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD BrightView LED-backlit (1366 x 768)
Display size (diagonal)
15.6"
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
2 USB 3.0 (1 HP USB Boost); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.45 x 26.11 x 2.52 cm
Starting at 2.09 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion polymer
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
FreeDOS 2.0
