    Fix HP Printer issue on macOS
HP Elite x2 1012 G1 Specifications
Product image
Figure : HP Elite x2 1012 G1
HP Elite x2 1012 G1
Product features
Feature
Processor
Intel Core M7-6Y75 with Intel HD Graphics 515 (1.2 GHz, up to 3.1 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores), vPro Support
Intel Core M5-6Y57 with Intel HD Graphics 515 (1.1 GHz, up to 2.8 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores), vPro Support
Intel Core M5-6Y54 with Intel HD Graphics 515 (1.1 GHz, up to 2.7 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores)
Intel Core M3-6Y30 with Intel HD Graphics 515 (0.9 GHz, up to 2.2 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores)
Integrated with processor
Graphics
Intel HD graphics 515
Ports/slots
1 USB Type-C, supporting USB 3.1 (supports Thunderbolt 3)
1 USB Type-A, supporting USB 3.0
1 Headphone /microphone combo
1 Micro SIM drawer (optional)
Micro SD Media Reader Drawer -supports microSD, microSDHC, microSDXC
Lock slot
Sensors
Accelerometer
Magnetometer
Gyro
ALS (ambient light sensor)
Proximity (SAR for WWAN)
Hail sensor
Feature
Internal
12 in diagonal LED-backlit BV UWVA eDP 1.3 Ultra-slim (1920 x 1280 – Full HD) touch screen chemically-strengthened Corning Gorilla Glass 4 top cover directly bonded to display
Refresh rate: 60 Hz
Brightness: 340 nits
Pixel resolution: 1920 x 1280 (WUXGA+) format, RGB stripe configuration
Interface: eDP 1.3
LCD mode: IPS/FFS/VA
PPI: 192 PPI
Viewing angle: UWVA 85/85/85/85 (left/right/down/up)
External
Up to 3840 x 2160 at 60 Hz for a single display, lower with additional displays connected (DisplayPort), HDMI from the side adapter is limited to 1920 x 1080 at 60 Hz
24-bit + 8 bit alpha channel (standard)
Up to 30-bit per pixel color depth (wide color gamut)
Storage and drives
Feature
Internal storage
Supports M.2 solid state drive SS 2280
128 GB SATA III solid state drive
180 GB SATA III solid state drive
180 GB SATA III SED OPAL2 solid state drive
256 GB SATA III solid state drive
256 GB SATA III solid state drive NVMe
256 GB SATA III SED OPAL2 solid state drive
512 GB SATA III solid state drive
Expansions storage
Micro SD media reader slot: Supports microSD, microSDHC, microSDXC, supporting expansion up to 200 GB
Memory
Feature
Standard
4 GB total system memory
8 GB total system memory
Maximum
Up to 8 GB
Networking/communication
Feature
Wireless
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and is supported via combo card.
Wireless WAN (WWAN)
HP hs3110 HSPA+ Intel Mobile Broadband
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband
HP lt4225 LTE/EV-DO Gobi 4G Mobile Broadband
HP lt4226 LTE/HSPA+ Gobi 4G Mobile Broadband
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 8260 802.11a/b/g/n/ac (2x2) WiFi and Bluetooth 4.2 Combo
Intel Tri Band Wireless-AC 18260 802.11a/b/g/n/ac (2x2) and Bluetooth 4.2 + WiGig Combo
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
Dual speakers (top facing)
Dual microphone array with echo cancellation, noise suppression
Headphone line-out and microphone-in (combo)
HP Advanced Noise Reduction Software
Camera
Front
  • Integrated 2 MP
  • 1080 p format for video
  • 2 MP for still capture
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1920 x 1080 resolution (1080 p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Back
  • 5 MP for still capture
  • High quality auto focus lens
Software and security
Feature
BIOS
HP BIOSphere
HP Sure Start with Dynamic Protection
HP DriveLock | HP Automatic DriveLock
HP BIOS Protection
HP SpareKey
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Pre-Boot Security
Secure Erase
Hybrid Boot (Windows 8.1 only)
Measured Boot (Windows 8.1 only)
Secure Boot (Windows 8.1 only)
Absolute Persistence Module
Multimedia
Cyberlink Power DVD
Cyberlink Power2Go
Communication
HP Mobile Connect Pro
Intel Wi-Di Software
HP Value Add software
HP ePrint Driver
HP Hotkey Support
HP Support Assistant
HP Recovery Manager (Windows 7 only)
HP Recovery Disc Creator (Windows 7 only)
HP Noise Reduction Software
3rd party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing Search
Skype
Manageability
HP Driver Packs
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP client catalog
HP CIK for Microsoft SCCM
LANDESK management
HP Touchpoint Manager
Client security software
HP Security Manager (including Credential Manager and Password Manager)
HP Drive Lock
HP Fingerprint Sensor
HP Password Manager
Microsoft Security Essentials
Microsoft Defender
Security
TPM 2.0 Embedded Security Chip (Common Criteria EAL4+ Certified)
HP Fingerprint Reader (selected models)
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Feature
Power supply
45 W USB Type-C AC Adapter
USB Type-C DC integrated cord (1.8 m)
AC Power cord (0.45 m)
Primary battery
HP 4-cell, long life 40 WHr Li-Ion
Voltage - 7.7 V
Physical specifications
Feature
820 g (1.8 lb)
Dimensions (W x D x H)
300 x 213.5 x 8.05 mm (11.8 x 8.4 x 0.3 in)
Feature
Preinstalled
Windows 10 Pro 64
Web-only support
Windows 10 Pro 64
Windows 10 Enterprise 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 8.1 Enterprise 64
