HP ProDesk 400 G3 Small Form Factor Business PC - Specifications
Weight and dimensions
Specification
Chassis (W x H x D)
95 x 270 x 299.5mm (3.7 x 10.6 x 11.8 in)
System volume
7.7 L
System weight
4.43 kg (9.8 lb)
Max supported weight (desktop orientation)
4.4 kg
Tower stand (H x W x D)
27.29 x 151.75 x 190 mm (1.15x 5.97 x 7.48 in)
Packaged (H x W x D)
440 x 210 x 520 mm (17.32 x 8.27 x 20.47 in )
Shipping weight
7.07kg (15.58 lb)
Palletization profile
Sea
10 units per layer
4 layers max
40 units per pallet
Air
10 units per layer
2 layers max
20 units per pallet
Processors
Specification
Intel 100 Series H110 Chipset
Graphics
Intel HD Graphics (integrated)
Intel Core i7-6700 processor
65W
Up to 4.0 GHz Max. Turbo Frequency (3.4 GHz base frequency)
8 MB cache, 4 cores, 8 threads
Intel HD Graphics 530
Supports DDR4 memory up to 2133 MT/s data rate
Intel Core i5-6600 processor
65W
Up to 3.9 GHz Max. Turbo Frequency (3.3 GHz base frequency)
6 MB cache, 4 cores, 4 threads
Intel Core i5-6500T processor
35W
Up to 3.1 GHz Max. Turbo Frequency (2.5 GHz base frequency)
Intel Core i3-6320 processor
65W
3.9 GHz base frequency
4 MB cache, 2 cores, 4 threads
Intel Core i3-6300 processor
65W
3.8 GHz base frequency
Intel Core i3-6100 processor
65W
3.7 GHz base frequency
3 MB cache, 2 cores, 4 threads
Intel Pentium G4520 processor
65W
3.6 GHz base frequency
3 MB cache, 2 cores, 2 threads
Intel Pentium G4500 processor
35W
3.0 GHz base frequency
Intel Pentium G4400 processor
35W
Intel HD Graphics 510
Ports
Specification
USB 3.0
2 - front (including 1 fast charging)
2 - rear center facing
USB 2.0
4 - rear center facing
Serial (RS-232)
1
Second serial
1 (optional)
PS/2
1 keyboard (purple)
1 mouse (green)
Video
1 VGA
1 DisplayPort with multi-stream
Audio
Front - headphone/mic
Rear - line out
3.5 mm diameter
RJ-45
Parallel
Optional
DisplayPort expansion card
N/A
Slots
Specification
PCI express x1 (v 2.0)
1 - 2.5 in full height, 6.6 in length 10W max. power
PCI express x1 (v 3.0)
N/A
PCI express x16 (v 3.0) (wired as a x4)
N/A
1 - 2.5 in full height, 6.6 in length 35W max. power
Bays
Specification
9 mm Slim ODD
1
Secure digital (SD) reader
1 (optional)
3.5 in internal storage driver
1
2.5/3.5 in internal storage driver
1
Operating systems
Specification
Preinstalled
Windows 10 Pro 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)
Windows 7 Professional 32 (available through downgrade rights from Windows 10 Pro)
FreeDOS 2.0
Web-supported
Windows 10 Pro 64
Windows 8.1 Pro 64
Windows 8.1 64
Windows 10 Enterprise 64
Windows 8.1 Enterprise 64
Windows 7 Enterprise 64
Windows 7 Enterprise 32
Software and security
Specification
BIOS
HP BIOSphere
HP DriveLock
HP BIOS Protection
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase
Hybrid Boot (Windows 8.1 & higher)
Measured Boot (Windows 8.1 & higher)
Secure Boot (Windows 8.1 & higher)
Absolute Persistence Module
Multimedia
Cyberlink Power DVD, BD
Cyberlink Power2Go (Secure Burn)
Communication
Intel Wireless Display (WiDi) Software for Windows
Native Miracast Support
HP value add software
HP ePrint Driver
HP Recovery Disc Creator (Windows 7 only)
HP Recovery Manager
HP Support Assistant
Windows 10 Welcome App
3rd party
Foxit PhantomPDF Express for HP
Microsoft products
Buy Office
Bing Search
Skype
Manageability
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM)
HP BIOS Config Utility (BCU)
HP Client Catalog
HP CIK for Microsoft SCCM
LANDESK Management
Discover HP Touchpoint Manager
Client security software
HP Drive Encryption
HP Client Security Manager
Microsoft Security Essentials
Microsoft Defender
TPM 1.2/2.0
Graphics card
Intel HD graphics (integrated)
Specification
DisplayPort
Multimode capable; supports HDCP, Display Port Audio (2 streams), HBR2 link rates and Multi-Stream Technology for a maximum of 3 displays (including the integrated panel)
Memory
The BIOS has options for selecting the dedicated memory size of 128 MB, 256 MB or 512 MB
Additional memory is allocated for graphics as needed using Intel's Dynamic Video Memory Technology (DVMT), to provide an optimal balance between graphics and system memory use.
Maximum graphics memory
Windows 7: Up to 1.7 GB
Windows 8.1: Up to 1.8 GB
Windows 10: > 4 GB
Maximum color depth
32 bits/pixel
Graphics/video API support
6th generation core processors:
Next Generation Intel Clear Video Technology HD Support is a collection of video playback and enhancement features that improve the end user's viewing experience.
  • Encode/transcode HD content
  • Playback of high definition content including Blu-ray Disc
  • Superior image quality with sharper, more colorful images
DirectX Video Acceleration (DXVA) support for accelerating video processing
  • Full AVC/VC1/MPEG2 HW Decode
Advanced Scheduler 2.0, 1.0
Windows 7, Windows 8, Linux OS Support
DirectX 12.1
Open GL 4.4
Open CL 1.2 (Intel HD Graphics 510)
Open CL 1.2/2.0 (Intel HD Graphics 530)
Supported display resolutions and refresh rates
Resolution
Refresh rates
800 x 600
60 Hz
1024 x 768
60 Hz
1152 x 864
60 Hz
1280 x 600
60 Hz
1280 x 720
60 Hz
1280 x 960
60 Hz
1280 x 1024
60 Hz
1360 x 768
60 Hz
1366 x 768
60 Hz
1400 x 1050
60 Hz
1440 x 900
60 Hz
1600 x 900
60 Hz
1600 x 1200
60 Hz
1680 x 1050
60 Hz
1920 x 1080
60 Hz
1920 x 1200
60 Hz
1920 x 1440
60 Hz
2560 x 1440
60 Hz
2560 x 1600
60 Hz
3840 x 2160
60 Hz
AMD Radeon R9 350 1 GB PCIe x16
Specification
Memory
2 GB 128-bit wide frame buffer operating at 1150 MHz
Controller clock speed
AMD Radeon R9 350 GPU operating at 925 MHz
Multidisplay support
A maximum of 4 displays are supported by the card. A maximum of 2 legacy displays (Native VGA, DVI, or displays connected with passive DisplayPort adapters are considered as legacy)
Graphics/API support
DIRECTX 11.1, Open GL 4.3, Open CL1.2, UVD 3
Output connectors
1 x Dual-Link DVI-I, 2x DisplayPort; includes DVI to VGA adapter
NVIDIA GeForce GT 730 2 GB PCIe x8 graphics card
Specification
Get impressive graphics and high resolution dual-display performance in a low profile, PCI Express x8 graphics add-in card based on the NVIDIA Kepler Graphics Processor. Improve your everyday PC, Web conferencing, and video or photo editing.
Memory
2 GB DDR3 64-bit wide frame buffer operating at 900 MHz
NVIDIA Kepler GPU operating at 902 MHz
Multi-display support
Supports Microsoft DirectX 12, OpenGL 4.4 and OpenCL 2 APIs, Shade Model 5, UVD 4.2, VCE 2.0, and DirectCompute 11
Output connectors
1 x Dual-Link DVI-I, 1x DisplayPort; Includes DVI to VGA adapter Display Port output is multi-mode capable, support audio, HBR2 and MST
NVIDIA NVS 310 graphics card
Specification
The NVIDIA NVS 310 Graphics Card is a PCI Express low profile form factor graphics add-in card targeted as an active low cost graphics solution for the corporate business and enterprise markets. The NVIDIA NVS 310 graphics card is an ideal solution for customers requiring a small form factor graphics add-in card for either standard or small form factor PC designs.
Performance and features
The NVIDIA NVS 310 Graphics Card offers 512 MB of ultrafast DDR3 memory and is capable of supporting up to 2 displays.
DisplayPort connector supports multimode technology to support connection to DVI-D, VGA and HDMI monitors with optional adapters in kits NR078AA, FH973AT, BP937AA, AS615AA.
For a DisplayPort to DisplayPort connections use the optional DisplayPort Cable Kit VN567AA.
Form factor
Low Profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 310
Memory clock
875 MHz
Memory size
512 MB DDR3
Memory bandwidth
14 GB/s
Max power
19.5 W
Display max resolution
Up to 2560 x 1600 (digital display) per display
Display output
Up to 2 displays in the following configurations
DisplayPort output
  • Drives two DisplayPort enabled digital display at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected natively using the 2 DisplayPort connectors on the NVS 310 graphics card
  • Supports 2 monitors up to resolution of 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort Multi-Stream topology technology
DVI-D output
  • Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors
  • Drives two digital display at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors
HDMI output
  • NVS 310 is capable of driving two high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors
VGA display output
  • Drives two analog display at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors
Hard disk and solid state storage
2 TB 7.2K rpm SATA 6.0 Gb/s 3.5 in hard disk drive
Specification
Unformatted capacity
2 TB
Rotational speed
7,200 rpm
Interface
Serial ATA 6.0 Gb/s
Cache, multi-segmented (MB)
64 MG
Seek time
Read: < 8.5 ms
Write: < 9.5 ms
Dimensions (H x W x L)
26.11 x 101.6 x 146.99 mm (1.02 x 4 x 5.78 in)
626 g (1.38 lb)
Operating temperature
5° to 55° C (41° to 131° F)
1 TB 7.2K rpm SATA 6.0 Gb/s 3.5 in hard disk drive
Specification
Capacity
1 TB
Rotational speed
7200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
32 MB
Logical blocks
1,953,525,168
Seek time
Single track: 2 ms
Average: 11 ms
Full-stroke: 21 ms
Dimensions (H x W)
2.54 x 10.2 cm (3.5 x 4 in)
500 GB 7.2K rpm SATA 6.0 Gb/s 3.5 in hard disk drive
Specification
Capacity
500 GB
Rotational speed
7,200 rpm
Interface
Buffer size
16 MB
Logical blocks
976,773,168
Seek time
Single track: 2 ms
Average: 11 ms
Full-stroke: 21 ms
Dimensions (H x W)
Environmental (non-condensing)
Operating temperature: 5° to 55° C (41° to 131° F)
1 TB SATA 6 G 2.5 in 8 GB solid state hybrid drive (SSHD)
Specification
Formatted capacity
1 TB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid state hybrid drive (SSHD) technology with NAND Flash
Interface
Serial ATA
Cache buffer
64 MB
NAND flash commercial multilevel cell (cMLC)
8 GB
Number of sectors
976,773,168
Seek time
Single track: 2 ms
Average: 12 ms
9.5 x 69.85 x 100.35 mm (0.37 x 2.75 x 3.95 in)
115 g (0.25 lb)
500 GB SATA 6 G 2.5 in 8 GB solid state hybrid drive (SSHD)
Specification
Formatted capacity
500 GB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid state hybrid drive (SSHD) technology with NAND flash
Interface
Serial ATA
Cache buffer
64 MB
8 GB
Number of sectors
976,773,168
Seek time (typical)
Single track: 2 ms
Average: 12 ms
6.8 x 69.85 x 100.35 mm (0.26 x 2.75 x 3.95 in)
95 g (0.2 lb)
512 GB SATA 2.5 in 3D non-SED solid state drive
Specification
512 GB
Architecture
Solid state drive with 3D NAND Flash and SATA interface
Interface
SATA 3.0 (6 Gb/s)
Form factor
2.5 in
6.8 x 69.85 x 100.2 mm (0.26 x 2.75 x 3.94 in)
54 g
Bandwidth performance
Sustained sequential read: up to 540 MB/s
Sustained sequential write: up to 500 MB/s
Power consumption (typical)
Active: 250 mW
Idle: 50 mW
Mean time between failure (MTBF)
1,500,000 hours
Operating temperature: 0° to 70° C (32° to 158° F)
Relative humidity: 5% - 95%
Shock: 1,500 G/0.5 ms
HP 256 GB SATA 6 Gb/s SSD
Specification
Capacity
256 GB
Interface
SATA 6 Gb/s
Synchronous transfer rate
Sustained reads: up to 560 MB/s
Sustained writes: up to 510 MB/s
Random read: up to 100K IOPs
Random writes: 88K IOPs
Active: 150 mW
Idle: 70 mW
256 GB SATA 2.5 in 3D Non-SED solid state drive
Specification
256 GB
Architecture
Fully complies with ATA/ATAPI-7 standard (Partially Complies with ATA/ATAPI-8)
Power saving modes: DIPM (Partial / Slumber mode)
Support NCQ: Up to 32 depth
Synchronous signal recovery
Interface
SATA 3.0 (6 Gb/s)
Form factor
2.5 in
54 g
Data transfer rate
Sustained sequential write: up to 280 MB/s
Active: 250 mW
Idle: 50 mW
1,500,000 hours
180 GB SATA Opal2 SED SSD (Intel Pro 2500)
Specification
Formatted capacity
180 GB
Architecture
Solid state drive with SATA interface; ATA 8 Compliant and SATA 3.0 compliant
Interface
Serial ATA 3 (6.0 Gb/s)
Form factor
2.5 in
7 x 69.85 x 100.45 mm (0.27 x 2.75 x 3.95 in)
78 g
Data transfer rate
Sequential read: up to 540 MB/s
Sequential write: up to 490 MB/s
Power consumption
Power-up: 6W
Read: <3.7 W
Write: 3.7 W
Standby: <55 mW
DEVSLP: <7 mW
Environmental
Shock: 1500 G (operating)
120 GB SATA 2.5 non-SED SSD
Specification
120 GB
Architecture
Multi-level cell (MLC) NAND
Interface
Form factor
2.5 in
78 g
Sustained sequential write: up to 480 MB/s
Read: <3.7 W
Write: 3.7 W
Standby: <55 mW
Environmental
128 GB SATA 2.5 in 3D non-SED solid state drive
Specification
128 GB
Architecture
Solid State Drive with 3D NAND Flash and SATA interface
Fully complies with ATA/ATAPI-7 standard (partially complies with ATA/ATAPI-8)
Power saving modes: DIPM (partial / slumber mode)
Interface
SATA 6 GB/s
Form factor
2.5 in
54 g
Sustained sequential read: up to 530 MB/s
Sustained sequential write: up to 140 MB/s
Active: 250 mW
Idle: 50 mW
1,500,000 hours
Environmental
Operating temperature: 0° to 60° C (32° to 140° F)
120 GB SATA 2.5 in Opal2 SED solid state drive (Pro 2500)
Specification
120 GB
Architecture
Supports Mode 2 Multiword DMA
Supports Drive Failure Prediction
Supports SMART Offline Read Scan
Supports Mode 4 PIO
Supports Mode 5 UDMA
Supports HP Drive Protection System
ATA 8 ACS-2 Data / TRIM Support
Support DEVSLP feature
Supports TRIM Command per ATA8 / ACS 2
Supports FIPS-197 features
Support TCG Storage Architecture Core Specification 2.0
Interface
SATA 3.0 (6 GB/s)
Form factor
2.5 in
78 g
Read: <3.7 W
Write: 3.7 W
Standby: <55 mW
Environmental
256 GB SATA 2.5 in Opal2 SED solid state drive
Specification
256 GB
Architecture
Self-Encrypting (SED) solid state drive with NAND Flash and SATA interface
Trusted Computing Group(TCG) OPAL2.0 compliant encrypted solid state drive
Interface
SATA (6.0 GB/s)
Form factor
2.5 in
73 g (0.16 lb)
Sustained sequential read: 520 MB/s
Sustained sequential write: 460 MB/s
Power consumption
Active: 3.89 W
Idle: 0.08 W
1,500,000 hours
Environmental
180 GB SATA 2.5 in Opal2 SED solid state drive (Pro 2500)
Specification
Formatted capacity
180 GB
Architecture
Supports Mode 4 PIO
Interface
SATA 3.0 (6 GB/s)
Form factor
2.5 in
Sustained sequential write: up to 490 MB/s
Power consumption
Read: <3.7 W
Write: 3.7 W
Standby: <55 mW
Environmental
Humidity: 5% - 95%
128 GB SATA 2.5 in Opal2 SED solid state drive
Specification
128 GB
Architecture
Interface
SATA 2 (6 GB/s)
Form factor
2.5 in
73 g
Sustained sequential write: 340 MB/s
Power consumption
Active: 3.89W
Idle: 0.02 W
1,500,000 hours
Environmental
Specification
Formatted capacity
180 GB
Architecture
Interface
SATA 3 (6 GB/s)
Form factor
2.5 in
78 g
Data transfer rate (128k sequential)
Sequential read: 540 MB/s
Sequential write: 490 MB/s
Power
Power-up: 6 W
Read: <3.7 W
Write: 3.7 W
Standby: < 55 mW
DEVSLP: <7 mW
Relative humidity: 5% to 95%
HP 128 GB turbo drive SSD-M.2 PCIe card
Specification
128 GB
Interface
M.2 PCIe x4 Gen 2
Architecture
Solid state drive M.2 PCIe Gen 2 x4 AHCI; NCQ Command Set
Form factor
M.2 2280
Dimensions (W x H x L)
22 x 80 x 3.73 mm (0.89 x 3.14 x 0.14 in)
8 g (0.01 lb)
Sustained sequential read: 920 MB/s
Sustained sequential write: 430 MB/s
Random read: 8500 IOPs
Random write: 32000 IOPs
Power
Allowable voltage: 3.3V ± 5%
Total power consumption
Active: 5.8 W
Idle: 80 mW
Mean time before failure
1.5 M hours
Shock: 1500 G
Regulations
Safety TUV UL CB c-UL-us
  • TUV
  • UL CB
  • c-UL-us
EMC/EMI
  • CE (EU)
  • BSMI (Taiwan)
  • KCC (South Korea)
  • VCCI (Japan)
  • C-Tick (Australia)
  • FCC (USA)
HP 256 GB turbo drive SSD-M.2 PCIe card
Specification
256 GB
Interface
M.2 PCIe Gen 2 x4
Architecture
Form factor
M.2 2280
0.8 x 7 x 50 mm (0.03 x 0.27 x 1.96 in)
10 g
Data transfer rate
Sequential read: 2150 MB/s
Sequential write: 1200 MB/s
Power
Power-up: N/A
Read: 4 W
Write: 5.1 W
Standby: 700 mW
Idle: 70 mW
Shock: 1000 G peak (operating)
Optical drives
HP 9.5 mm Desktop G2 Slim SuperMulti DVD writer drive
Specification
Height
9.5 mm (0.37 in)
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5 GB DL or 4.7 GB standard
128 x 12.7 x 127 mm (5.04 x 0.37 x 5 in) without bezel
140 g (0.31 lb)
Write speeds
DVD-RAM: Up to 5x
DVD-R DL: Up to 6x
DVD+R: Up to 8x
DVD+RW: Up to 8x
DVD+R DL: Up to 6x
DVD-R: Up to 8x
DVD-RW: Up to 6x
CD-R: Up to 24x
CD-RW: Up to 10x
Read speeds
DVD-RAM: Up to 5x
DVD-RW, DVD+RW: Up to 8x
DVD-R DL, DVD+R DL: Up to 8x
DVD+R, DVD-R: Up to 8x
DVD-ROM DL, DVD-ROM: Up to 8x
CD-ROM, CD-R: Up to 24x
CD-RW: Up to 24x
Access time (typical)
Random: DVD-ROM and CD-ROM 170 ms
Full stroke: DVD-ROM and CD-ROM 320 ms
Stop time: 6 seconds
Power
Source: Slimline SATA DC power receptacle
DC power requirement: 5 VDC ± 5%-100 mV ripple p-p
DC current: 5 VDC (< 1000 mA typical, 1600 mA maximum)
Temperature: 5° to 50° C (41° to 122° F)
Relative humidity: 10% - 80%
Maximum wet bulb temperature: 29° C (84° F)
HP 9.5 mm Desktop G2 Slim SATA BDXL Blu-Ray writer
Specification
Height
9.5 mm (0.37 in)
Orientation
Interface type
SATA/ATAPI
Up to 128 GB QL, 100 GB TL, 50 GB DL or 25 GB standard SL
128 x 12.7 x 127 mm (5.04 x 0.5 x 5 in) without bezel
170 g (0.37 lb)
Write speeds
Triple-layer
Quadruple-layer
BD-R
Up to 4x
Up to 4x
BD-RE
Up to 2x
Note supported
Single-layer
Double-layer
BD-R
Up to 6x
Up to 6x
BD-RE
Up to 2x
Up to 2x
DVD-R
Up to 8x
Up to 6x
DVD-RW
Up to 6x
Not supported
DVD+R
Up to 8x
Up to 6x
DVD+RW
Up to 8x
Not supported
DVD-RAM
Up to 5x
CD-R
Up to 24x
CD-RW
Up to 24x
Triple-layer
Quadruple-layer
BD-R
Up to 6x
Up to 4x
BD-RE
Up to 4x
Not supported
Read speeds
Single-layer
Double-layer
BD-ROM
Up to 6x
Up to 6x
BD-R
Up to 6x
Up to 6x
BD-RE
Up to 6x
Up to 6x
DVD-ROM
Up to 8x
Up to 8x
DVD-R
Up to 8x
Up to 8x
DVD-RW
Up to 8x
DVD+R
Up to 8x
Up to 8x
DVD+RW
Up to 8x
BDMV (AACS Compliant Disc)
Up to 6x/2x (Read/Play)
DVD-RAM
Up to 5x
DVD-Video (CSS Compliant Disc)
Up to 8x/4x (Read/Play)
CD-R/RW/ROM
Up to 24x
CD-DA (DAE)
Up to 24x/10x (Read/Play)
Random
BD-ROM: 350 ms
DVD-ROM: 185 ms
CD-ROM: 165 ms
Full stroke
BD-ROM: 350 ms
DVD-ROM: 345 ms
CD-ROM: 340 ms
Power
DC current: 5 VDC -1200 mA typical, 2000 mA maximum
HP 9.5 mm desktop G2 slim DVD-ROM drive
Specification
Height
9.5 mm (0.37 in)
Orientation
Interface type
SATA/ATAPI
128 x 9.5 x 127 mm (5.04 x 0.37 x 5 in) without bezel
140 g (0.31 lb)
Read speeds
DVD+R/-R/+RW/ -RW/+R DL /-R DL: Up to 8x
DVD-ROM: Up to 8x
CD-ROM,CD-R: Up to 24x
CD-RW: Up to 24x
Random
DVD-ROM: 170 ms
CD-ROM: 170 ms
Full stroke
DVD-ROM: 320 ms
CD-ROM: 320 ms
Power
DC current: 5 VDC - < 1000 mA typical, < 1600 mA maximum
Networking and communications
Realtek RTL8111HSH-CG GbE
Specification
Ethernet features
10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
Auto-negotiation (automatic speed selection)
Full duplex operation at all speeds, half duplex operation at 10 and 100 Mbit/s
IEEE 802.1p QoS (quality of service) support
IEEE 802.1q VLAN support
IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
IEEE 802.3az EEE (energy efficient ethernet)
Jumbo Frame 9K
Auto MDI/MDIX crossover cable detection
Power management
ACPI compliant – multiple power modes
Situation-sensitive features reduce power consumption
Advanced link down power saving for reducing link down power consumption
Performance features
TCP/IP/UDP Checksum Offload (configurable)
Protocol Offload (ARP & NS)
Large send offload and Giant send offload
Receiving Side Scaling
Manageability
Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
PXE 2.1 Remote Boot
Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30)
Comprehensive diagnostic and configuration software suite
Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
PCIe GBE Ethernet Family Controller
Broadcom BCM943228Z 802.11n 2x2 DualBand Combo PCIe x1 Card
Specification
Wireless LAN standards
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
    The FCC has declared as of January 1, 2015 products that utilize passive scanning on channel 12/13 and are capable of transmitting must fully comply with requirements of 15.247 or otherwise disable those channels.
802.11a/n
  • 4.9 - 4.95 GHz (Japan)
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
    This band not supported in Indonesia
Antenna structure
2 transmit
2 receive (2x2)
Data rates
802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11b: 1, 2, 5.5, 11 Mbps
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
802.11n: MCS 0 ~ MCS 15, (20 MHz, and 40 MHz)
Modulation
Direct Sequence Spread Spectrum
CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
IEEE and Wi-Fi compliant 64 / 128 bit WEP encryption for a/b/g mode only
AES-CCMP: 128 bit in hardware
802.1x authentication
WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
WPA2 certification
IEEE 802.11i
Cisco Certified Extensions, all versions through CCX4 and CCX Lite
WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Network architecture models
Ad-hoc (peer to peer)
Infrastructure (access point required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power
802.11b: +16 dBm minimum
802.11g: +14 dBm minimum
802.11a: +14 dBm minimum
802.11n HT20 (2.4 GHz): +13 dBm minimum
802.11n HT40 (2.4 GHz): +13 dBm minimum
802.11n HT20 (5 GHz): +12 dBm minimum
802.11n HT40 (5 GHz): +12 dBm minimum
Power consumption
Transmit: 2 W
Receive: 1.6 W
Idle mode (PSP): 180 mW (WLAN associated)
Idle mode: 60 mW (WLAN unassociated)
Radio disabled: 30 mW
Power management
ACPI and PCI Express compliant power management
802.11 compliant power saving mode
Receiver sensitivity
802.11b, 1Mbps: -94 dBm maximum
802.11b, 11Mbps: -86 dBm maximum
802.11g, 6Mbps: -88 dBm maximum
802.11g, 54Mbps: -74 dBm maximum
802.11a, 6Mbps: -86 dBm maximum
802.11a, 54Mbps: -72 dBm maximum
802.11n, MCS07: -69 dBm maximum
802.11n, MCS15: -66 dBm maximum
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO and Bluetooth communications
Form factor
PCI-Express M.2 MiniCard
Dimensions
Type 2230: 2.3 x 22 x 30 mm
Type 1630: 2.3 x 16 x 30 mm
Type 2230: 2.8 g
Type 1630: 2 g
Environmental
Operating voltage
  • 3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C (14° to 158° F)
  • Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 0 to 3,048 m (10,000 ft)
  • Non-operating: 0 to 15,240 m (50,000 ft)
LED activity
LED Amber - Radio OFF; LED White - Radio ON
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Specification
Bluetooth specification
4.0+EDR Compliant
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
3 Mbps data rate; throughput up to 2.17 Mbps
Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit power
The Bluetooth component shall operate as a Class II Bluetooth device with a maximum transmit power of +4 dBm for BR and EDR
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Selective Suspend 17 mW
Range
Up to 10 m (33 ft)
Electrical interface
USB 2.0 compliant
Bluetooth software supported link topology
Microsoft Windows Bluetooth Software
Electrical interface Bluetooth software supported security
Point to point, multipoint pico nets up to 7 slaves
Full support of Bluetooth security provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Security
All necessary regulatory approvals for supported countries, including FCC (47 CFR) Part 15C, Section 15.247 and 15.249
Power management certifications
ETS 300 328, ETS 300 826
Low Voltage Directive IEC950
Bluetooth profiles supported
UL, CSA, and CE Mark Serial Port Profile (SPP)
Service Discovery Application Profile (SDAP)
Dial-Up Networking (DUN)
Generic Object Exchange Profile (GOEP)
Object Push Profile (OPP)
File Transfer Profile (FTP)
Synchronization Profile (SYNC)
Hard Copy Cable Replacement (HCRP)
Personal Area Networking Profile (PAN)
Human Interface Device Profile (HID)
FAX Profile (FAX)
Basic Imaging Profile (BIP)
Headset Profile (HSP)
Hands Free Profile (HFP)
Advanced Audio Distribution Profile (A2DP)
Intel 7265 802.11ac 2x2 DualBand Combo PCIe x1 Card
Specification
IEEE 802.11a
IEEE 802.11b
IEEE 802.11g
IEEE 802.11n
IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency band
802.11b/g/n
  • 2.402 – 2.482 GHz
802.11a/n
  • 4.9 – 4.95 GHz (Japan)
  • 5.15 – 5.25 GHz
  • 5.25 – 5.35 GHz
  • 5.47 – 5.725 GHz
  • 5.825 – 5.850 GHz
Data rates
802.11ac: MCS0 ~ MCS9, (1SS, and 2SS) (20 MHz, 40 MHz, and 80 MHz)
Modulation
BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
WPA2 certification
IEEE 802.11i
WAPI
Roaming
IEEE 802.11 compliant roaming between access points
Output power
802.11ac 80 MHz (5 GHz): +11 dBm minimum
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Power management
802.11ac, 1SS, MCS-0: -86 dBm maximum
802.11ac, 1SS, MCS-9: -61 dBm maximum
802.11ac, 2SS, MCS-0: -83 dBm maximum
802.11ac, 2SS, MCS-9: -58 dBm maximum
Antenna type
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form factor
Dimensions
Type 2230: 2.8 g
Type 1630: 2 g
Environmental
Operating voltage
  • 3.3v +/- 9%
Temperature
  • Operating: –10° to 70° C (14° to 158° F)
  • Non-operating: –40° to 80° C (–40° to 176° F)
Humidity
Altitude
LED activity
LED Amber – Radio OFF; LED White – Radio ON
Specification
4.0+EDR Compliant
Frequency band
2402 to 2480 MHz
Transmit power
Modulation
0.01% BER
0.001% BER
GFSK
-80 dBm
-70 dBm
π/4-DQPSK
-80 dBm
-70 dBm
8DPSK
-80 dBm
-70 dBm
Power consumption
Peak (Tx) 330 mW
Peak (Rx) 230 mW
Range
Up to 10 m (33 ft)
USB 2.0 compliant
Microsoft Windows Bluetooth software
Power management
Security
All necessary regulatory approvals for supported countries, including FCC (47 CFR) Part 15C, Section 15.247 & 15.249
Certifications Bluetooth profiles supported
FAX Profile (FAX)
Input/output devices
HP Conferencing Keyboard
Specification
Physical characteristics
Keys
110 (US) Layout, 111 (EU) Layout – depending upon country
Dimensions (L x W x H)
2.16 x 44.05 x 15.50 cm (0.85 x 17.34 x 6.10 in)
700 g (24.69 lb)
Connectivity
USB cable
Feature summary
Full-size ultra-quiet keyboard with numerical pad and 12 function keys
One-touch simplicity for Microsoft Lync or Skype for Business calls with dedicated keys and LED light indicators
Illuminated keys
Incoming call – Blinks Green
Call in progress –Green
Microphone mute – Orange
Audio mute – Orange
Screen sharing – Orange
Stop webcam – Orange
Other call control keys
End/decline Call
Volume up and down rocker key
Microsoft Lync / Outlook
Fn+F12 – Lync or Skype for Business Calendar will open. If Lync or Skype for Business is not available will bring Outlook Calendar
Fn+F11 – Lync or Skype for Business Contact will open. If Lync or Skype for Business is not available will bring Outlook Contact list
* Fn+11 and Fn+12 function keys are not supported in Microsoft Windows 8.x Metro mode
Functions keys
Fn+F10 – System settings
Fn+F9 – Devices
Fn+F8 – Search
Fn+F7 – Blank
Fn+F6 – Up brightness adjustment
Fn+F5 – Down brightness adjustment
Fn+F4 – Display options
Fn+F3 – File explorer
Fn+F2 – System lock
Fn+F1 – System sleep
System requirements
Available USB port
Windows 7, Windows 8.x, and Windows 10
Server: Microsoft Lync Server 2010 or 2013 and Skype for Business Server 2015
Client: Microsoft Lync 2013 version 15.0.46xx or newer or Skype for Business
Limited support for Microsoft Lync 2010, Microsoft Lync 2013 Basic and Microsoft Metro Mode
Screen brightness functions supported in select HP systems
Approvals EMC product safety
FCC; CE; ACA (C-tick); EAC, UL, CE Mark
HP USB Business Slim Keyboard
Specification
Keys
104, 105, 106, 107, 109 layout (depending upon country)
436.8 ± 1.5 x 137.6 ± 1 x 21 ± 1 cm (171.97 x 68.35 x 8.27 in)
0.6± 0.08 kg (1.32 lb) minimum
Electrical
Operating voltage
+ 4.4 – 5.25 VDC
Power consumption
50 mA maximum (with 5 VDC power supplied and three LEDs ON)
System interface
USB Type A plug connector
ESD
Contact discharge: 2, 4,6,8 KV
Air discharge: 2, 4, 8,10,12.5 KV
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Keycaps
Low-profile design
Switch actuation
60 ± 12.5 g nominal peak force with tactile feedback
Switch life
10 million keystrokes (Life tester)
Switch type
Contamination-resistant switch membrane
Key-leveling mechanisms
For all double-wide and greater-length keys
Cable length
1.8 m (6 ft)
Mechanically compliant
Environmental
Acoustics
43 dBA maximum sound pressure level
Temperature
Operating: 10° to 50° C (50° to 122° F)
Non-operating: -30° to 60° C (-22° to 140° F)
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 20% to 80% (non-condensing at ambient)
Shock
Operating: 40 g, six surfaces
Non-operating: 80 g, six surfaces
Vibration
Operating: 2 g peak acceleration
Non-operating: 4 g peak acceleration
Drop (out of box)
66 cm (26 in) on carpet, six-drop sequence
Drop (in box)
76.2 cm (30 in) on concrete, 16-drop sequence
Approvals
UL, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, KC
Ergonomic compliance
ANSI HFS 100, ISO 9241-4, and TUVGS
Kit contents
Keyboard
Installation guide
Warranty card
Safety and comfort guide
HP Wireless Business Slim Keyboard and Mouse
Specification
Keyboard
Dimensions (H x L x W)
Weight - without two AA Alkaline batteries
560 ± 80 g (1.23 lb)
Mouse
37 x 115 x 62.9 mm (1.46 x 4.53 x 2.47 in)
67 g (0.15 lb)
Receiver
8.4 x 45.5 x 18.4 mm (0.33 x 1.79 x 0.72 in)
5.9 g (0.21 oz)
Cable length - minimum
1.8 m (6 ft)
Range
10 m (32.8 ft)
System requirements1
Available USB port for the receiver
CD-ROM Drive
This system may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality. See http://www.microsoft.com/windows/windows-7/ for details.
Approvals
Product safety
UL; CSA /TUV (Europe only); CE Mark; CB Report
Ergonomics
ANSI; ISO (Europe only); GS Mark (Germany only)
EMC
FCC; CE; ACA (-tick); BSMI; KC ; VCCI
CE mark
EN 55022:2010; EN 55024; EN 301489-1; EN 61000
Design guidelines for PCs
PC 99 – connector overmold colors; PC 2001 – full functionality
Telecom
All local telecom requirements and approvals for intended markets
USA
FCC Title 47 CFR, Par 15, Subpart C; other local requirements
Country support
Argentina, Australia, Austria, Belgium, Brazil, Bulgaria, Canada, Chile, China, Croatia Czech Republic, Cyprus, Denmark, Ecuador, Estonia, Finland, France, Germany, Greece, HK, Hungary, India, Indonesia, Ireland, Israel, Italy, Japan, Korea, Latvia, Lithuania, Luxemburg, Malta, Mexico, Malaysia, Netherlands, Norway, NZ, Peru, Philippines, Poland, Portugal, Romania, Russia, Singapore, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Thailand, Turkey, UK, Ukraine, United Arab Emirates, US, Venezuela, Vietnam, and up to 193 countries worldwide
Environmental
Keyboard contains 25% post-consumer recycled plastic material.
HP USB PS/2 Washable Keyboard
Specification
Physical Characteristics
449 x 168 x 35 mm (17.67x 6.62 x 1.38 in)
0.77 kg (1.7 lb)
Keys
104 (US) Layout, 105 (EU) layout – depending upon country
Electrical
Operating voltage
+ 5VDC ± 5%
Power consumption
50 mA maximum (with three LEDs ON)
System interface
ESD
CE level 4, 15 kV air discharge
EMI - RFI
Mechanical
Keycaps
Stepped profile design
Switch actuation
55 g nominal peak force with tactile feedback
Switch life
20 million keystrokes
Switch type
Cable length
2.2 m (7 ft)
Acoustics
Environmental
Temperature
Non-operating: -20° to 65° C (4° to 149° F)
Humidity
Operating: 10% to 95% (non-condensing at ambient)
Non-operating: 0% to 95% (non-condensing at ambient)
Shock
Vibration
Drop (out of box)
Drop (in box)
107 cm (42 in) on concrete, 16-drop sequence
Operating system support
Windows 7
Windows Vista
Windows XP Professional
Approvals
UL, cUL, FCC, CE, TUV GS, VCCI, BSMI, C-Tick, KCC, USB-IF, WHQL, EN/IEC 60601-1, IP66/NEMA4X
HP USB 1000dpi Laser Mouse
Specification
37.3 x 114.97 x 62.86 mm (1.47 x 4.53 x 2.47 in)
102 g (3.360 oz)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
Environmental
Temperature
Operating: 0° to 40° C (32° to 104° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Humidity
Mechanical
Resolution
1000 dpi
Tracking speed
45 cm/s
Cable length
180 cm (70.9 in)
Audio
High definition audio
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC3228-CG codec
Number of channels
Audio I/O ports
Front microphone-in
Rear line-in
Rear line-out
Front headphone-out
Front microphone
All ports are 3.5 mm
Internal speaker amplifier
1.5 W amplifier for the internal speaker only. External speakers must be powered externally.
Multi-streaming capable
Playback multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes - uses OS soft wavetable
Analog audio
Yes
Number of channels on line-out
Stereo (left and right channels)
Internal mono speaker
Yes
External speaker jack
Yes
Country: Flag Bulgaria
