HP ScanJet Pro 3500 f1 flatbed scanner - Sleep Mode and Auto-Off Settings
Sleep Mode and auto-off settings
By default, the scanner will enter Sleep Mode after 15 minutes of inactivity, and will turn off automatically after two hours of inactivity to conserve power.
Windows: To change the default auto-off settings, complete these steps:
  1. Start the HP Scanner Tools Utility by doing one of the following:
    • Click Start, point to Programs or All Programs, point to HP, point to ScanJet, point to 3500 f1, and then click Scanner Tools Utility.
    • On the Start screen, click to HP Scanner Tools Utility tile.
  2. Click the Settings tab, and then select the appropriate sleep mode and auto-off settings.
    • To specify the period of inactivity after which the scanner automatically turns off, select the appropriate value (1 hour, 2 hours, 4 hours, or Never) from the Auto-Off: Turn off the scanner after: drop down list.
OS X: To change the default auto-off setting use HP Utility.
  1. Start HP Utility.
  2. Click the Energy icon.
  3. Select a Lamp Mode setting.
  4. Select an auto-off time setting from the Automatically power off the scanner: drop down box.
