    Fix Windows 10 Update Issues
HP ScanJet Pro 3500 f1 Flatbed Scanner - Product Views
This section describes the physical components of the HP ScanJet Pro 3500.
Front view
Figure : Product front view
  • 1. Paper guides
  • 2. Document input tray
  • 3: Output stopper
  • 4. Document output tray
  • 5. Control panel
Back view
Figure : Scanner rear components
  • 1. USB port
  • 2. Power connector
Serial and product numbers
The serial and product numbers are located on the bottom of the scanner.
Figure : Product view, bottom
Control panel
Use the buttons on the control panel to start or cancel a scan, and to power the unit on and off.
Figure : Control-panel view
Callout
Name
1
Tools/Maintenance
2
Back
3
Scroll down
4
Scroll up
5
Ok
6
Simplex scan
7
Duplex scan
8
Sleep/Power
9
Cancel
