    Fix HP Printer issue on macOS
HP PageWide XL Printer Series Software/Firmware
Follow these steps to check for the latest firmware updates for your printer using the HP website.
  1. Turn on the printer.
  2. Type your printer model number, and then click Find.
  3. If prompted, select your printer from the list.
  4. Select your language if necessary, and then click the name of your operating system. A page listing all available downloads displays.
  5. In the Firmware section, click Download. Follow the on-screen instructions to save the file to your computer.
  6. Open the folder where you saved the file (usually Downloads), double-click the file, and then follow the on-screen instructions to complete the installation.
