HP LaserJet Pro M501, M506, MFP M527, HP LaserJet Managed E50045, E52545 - Removal and replacement: Tray 3
This document provides the procedures to remove and replace Tray 3.
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Tray 3 part number
RM2-5758-000CN
Cassette (Tray 3) assembly
Required tools
  • No special tools are required to remove this part.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Make sure that the printer initializes to a Ready state.
Print a page from Tray 3 to make sure that the paper feeder is functioning correctly.
Step 1: Remove the tray
  1. Pull the tray straight out of the printer until it stops.
    Figure : Pull the tray out of the printer
  2. Slightly lift up on the front of the tray to release it, and then continue to pull the tray out of the accessory to remove it.
    Figure : Release and remove the tray
Step 2: Unpack the replacement tray
Unpack the replacement part from the packaging.
Recycle and unpack
Figure : Recycle and unpack
Step 3: Install the tray
  1. With the tray at a slight angle, align the sides of the tray with the rails in the accessory, and then partially slide the tray into the accessory.
    Figure : Install the tray
  2. Push the tray straight into the accessory to close it.
    Figure : Close the tray
