HP Spectre x360 - 13-4124tu Product Specifications
P7G36PA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, 4 MB cache, 2 cores)
8 GB LPDDR3 SDRAM (onboard)
Video Graphics
Hard Drive
256 GB M.2 SSD
13.3" diagonal FHD BrightView LED-backlit touch screen (1920 x 1080)
Keyboard
island-style backlit keyboard
Pointing device
Wireless Connectivity
802.11/b/g/n (2x2) and Bluetooth® 4.0 combo (Miracast compatible); WiDi
External Ports
3 USB 3.0; 1 Mini DisplayPort; 1 HDMI; 1 headphone/microphone combo
32.5 x 21.8 x 1.59 cm
Starting at 1.45 kg
45 W AC power adapter
3-cell, 56 Wh Li-ion polymer
HP TrueVision Full HD WVA Webcam (front-facing) with integrated dual digital microphones
Dual speakers; DTS Studio Sound™; Bang & Olufsen
Pre-installed software
Cyberlink Youcam; Adobe® Shockwave® Player; User Guide Documentation; iPass
Buy Office
HP Recovery Manager; HP Support Assistant
