By default, the scanner will enter Sleep Mode after 15 minutes of inactivity, and will turn off automatically after two hours of inactivity to conserve power.
Windows: To change the default auto-off settings, use the Touch Panel or Embedded Web Server.
OS X: To change the default auto-off setting use the Energy Pane.
Start HP Utility.
Click the Energy icon.
Select a Lamp Mode setting.
Select an auto-off time setting from the Automatically power off the scanner: drop down box.
