    Fix HP Printer issue on macOS
HP Color LaserJet Pro M452 - Clear paper jams in Tray 2
Use the following procedure to check for a paper jam in Tray 2. When a jam occurs, the control panel displays an error message (2-line control panels) or an animation (touchscreen control panels) that assists in clearing the jam.
  1. Pull the tray completely out of the printer.
    Figure : Remove Tray 2
  2. Remove any jammed or damaged sheets of paper.
    Figure : Remove the jammed paper
  3. Reinsert and close Tray 2.
    Figure : Close the tray
