HP Pavilion 25xw IPS LED Backlit Monitor - Product Specifications
The HP Pavilion 25xw is a 63.5 cm (25 in) IPS LED Backlit monitor.
Figure : HP Pavilion 25xw IPS LED Backlit Monitor
25xw monitor front view
J7Y65AA
Technical specifications
LED feature
Specification
Display size
63.5 cm (25 in) diagonal
Display type
IPS with LED Backlight
Brightness
250 cd/m²
Color gamut
72%
Color support
up to 16.7 million colors supported through FRC technology
Pixel pitch
0.288 mm x 0.286 mm
88.1 PPI
Inputs
1 VGA
2 HDMI
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
7 ms (typical)
Power consumption
30 Watts max
Tilt
-2 to +25 degrees
Dimensions
W x D x H (unpacked):
57.7 x 16.5 x 42.4 cm (22.7 x 6.5 x 16.7 in)
Unpacked: 4.8 Kg (10.6 lbs)
