HP Color LaserJet Pro MFP M477 - Product views
Printer front view
    Figure : Printer front view
  1. Scanner
  2. Document feeder
  3. Regulatory label (inside the front door)
  4. Tray 2
  5. Tray 1
  6. Power on/off button
  7. Front door (provides toner cartridge access)
  8. Output bin extension
  9. Output bin
  10. Walk-up USB port (for printing and scanning without a computer)
  11. Touchscreen control panel (tilts up for easier viewing)
Printer back view
    Figure : Printer back view
  1. Front door release button
  2. Duplexer (fdn and fdw models only)
  3. USB port for job storage
  4. USB port for direct connection to a computer
  5. Ethernet port
  6. Fax ports
  7. Power connection
  8. Rear door (fnw model only) (provides access for clearing jams)
Control-panel view
    Figure : Control panel
  1. Touchscreen
  2. Home page screen indicator
  3. Help button
  4. Home button
  5. Back button
While the control panel does not have a standard Cancel button, during many printer processes a Cancel button appears on the touchscreen. This permits users to cancel a process before the printer completes it.
Home screen layout
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by touching the Home button on the printer control panel.
The features that appear on the Home screen can vary, depending on the printer configuration.
  1. Reset button
  2. Connection Information button
  3. Setup button
  4. Apps button
  5. Supplies button
  6. USB button
  7. Fax button
  8. Scan button
  9. Jobs button
  10. Copy button
  11. Printer status
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Setup button to open the Setup menu.
Swipe
Touch the screen and then move the finger horizontally to move the screen sideways.
Swipe the Home screen to access the Setup button.
Scroll
Touch the screen, and then, without lifting the finger, move the finger vertically to move the screen.
Scroll through the Setup menu.
