Document ID: c04784693
Version: 1
Advisory: HP ProBook 645, 650, and 655 Notebook PCs - Bluetooth Device Has Yellow Triangle With Exclamation Mark in Device Manager After Upgrade to Windows 10
Release date : 02-Sep-2015
Last updated : 03-Sep-2015
DESCRIPTION
After upgrading from Windows 7 to Windows 10, the Windows device manager flags Bluetooth devices with a yellow triangle and exclamation mark indicating that they are not working properly even though Bluetooth devices work normally.
SCOPE
Systems:
  • HP ProBook 645 G1 Notebook PC
  • HP ProBook 650 G1 Notebook PC
  • HP ProBook 655 G1 Notebook PC
Operating Systems:
  • Non-OS Specific
  • Microsoft Windows 10 Pro (64-bit)
RESOLUTION
The issue is cosmetic only. Bluretooth software and devices function normally even though the Device Manager indicates a problem.
Avoid the issue by removing the Windows 7 Bluetooth driver before upgrading.
If the issue is already occurring, run Windows Update or install the Windows 10 Bluetooth driver using the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
Broadcom Bluetooth Driver
Version: 12.0.1.695
Revision: A Pass: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www8.hp.com/us/en/drivers.html.
Hardware platforms affected : HP ProBook 645 G1 Notebook PC, HP ProBook 650 G1 Notebook PC, HP ProBook 655 G1 Notebook PC
Support Communication Cross Reference ID : IA04784693
