Compaq 14, HP 14, 15, and Pavilion 11 Notebook PCs - HP Wireless Button Driver Is Displayed as an Unknown Device After Upgrading From Windows 7 to Windows 10
The HP Wireless Button driver is displayed as an unknown device in Device Manager after upgrading from Windows 7 to Windows 10.
To resolve this issue, download and install the latest BIOS for your model computer, then download and install the following SoftPaq:
Step 1: Download and install the latest BIOS with HP Support Assistant.
  1. Open HP Support Assistant.
  2. Select Updates and Tune-ups.
  3. Click Check for updates now.
  4. In the Updates results list, check HP Notebook System BIOS update.
  5. Follow the on-screen instructions to download and install BIOS update.
  6. Restart the computer.
Step 2: Download and install the following SoftPaq.
SoftPaq Description
Release Notes
Download SoftPaq
Version: 1.1.2.1
Revision: A
The HP Wireless Button driver can also be downloaded and installed via Windows Updates.
