Remove and Replace the Memory Modules for HP Pavilion 15-abXXX Notebook PCs
This document applies to HP Pavilion 15-abXXX notebook computers.
HP Pavilion 15-ab000 notebook computer
Before you begin
  • Have available a pair of tweezers and a Phillips-head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations of HP Pavilion 15-abXXX notebook computers.
Removing the memory modules
To remove the memory modules, first follow the instructions to remove the battery, the optical drive, the rear corner covers, and the base enclosure, then follow the steps to remove the memory modules.
Step 1
Find the battery lock latch identified by the lock icon on the bottom of the computer and slide it to the unlock position.
Sliding the battery lock latch
Step 2
Find the battery release latch identified by the battery icon and slide the battery release latch to the release position to partially eject the battery.
Sliding the battery release latch to release the battery
Step 3
Lift the front edge of the battery and remove the battery from the battery bay.
Lifting and removing the battery
Step 4
Now remove the optical drive.
Remove the 6.5 mm P1 Phillips-head screw that secures the optical drive to the base enclosure.
Screw that secures the optical drive
Step 5
Grasp the optical drive bezel and carefully slide the optical drive out of the base enclosure.
Removing the optical drive
Step 6
Remove the rear corner covers
Remove the two 12 mm P1 Phillips-head screws that secure the corner covers to the base enclosure.
The screw locations that secure the corner covers
Step 7
Carefully lift the corner covers to disengage the tabs that secure them to the base enclosure and remove.
Removing the left cover
Removing the right cover
Step 8
Now, remove the base enclosure.
With a pair or tweezers, remove the two Mylar screw covers from the base enclosure.
Mylar covers to remove
Step 9
Remove the thirteen 6.5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Screw locations of the thirteen screws to remove
Step 10
Remove the two 5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Two screw locations
Step 11
Carefully separate the edges of the base enclosure from the top cover...
To prevent damage to the base enclosure, take extreme care when separating the area around the optical drive bay from the top cover.
Separating the edges of the base enclosure from the top cover
... and slide it off the display panel hinges.
Lifting  the base enclosure off the display panel hinges
Step 12
Find the memory modules.
Location of the memory module
Step 13
Push both arms outward simultaneously to release the memory module to the spring tension position.
When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
Pushing both latches out to release the memory module
Step 14
Grasp the memory module by the edges and pull gently to remove it.
Step 15
Place the memory module in a static dissipative bag.
Placing the memory module in a static dissipative bag
Replacing the memory modules
Use the steps in this section to replace the replace the components and the memory modules.
Step 1
Grasp the memory module by the edges and align the notch in the memory module with the key in the memory module slot on the system board.
Aligning the notch in the board with the key in the slot on the system board
Step 2
At an angle, gently insert the memory module into its slot on the system board.
Inserting the memory module into its slot
Step 3
Press the memory module down to latch the arms.
Pressing the memory module down
Step 4
Slide the base enclosure onto the display panel hinges.
Ensure that the wireless antenna and display panel cables are free from being pinched between the base enclosure and top cover.
Sliding the base enclosure onto the hinges
Step 5
Place the base enclosure into position on the top cover. Apply pressure to the edges of the base enclosure to snap it into place.
Applying pressure to snap the base enclosure into place
Step 6
Replace the two 5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Two screw locations
Step 7
Replace the thirteen 6.5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Thirteen screw locations
Step 8
Place the two Mylar screw covers into position on the base enclosure.
Mylar screw cover locations
Step 9
Align the corner covers with the base enclosure and press down on the corner covers to secure them into position.
Replacing the right corner cover
Replacing the left corner cover
Step 10
Replace the two 12 mm P1 Phillips-head screws that secure the corner covers to the base enclosure.
Screw locations to secure the corner covers
Step 11
Insert the optical drive into the optical drive bay...
Inserting the optical drive
...until the optical drive bezel is flush with the side of the base enclosure.
Optical drive is flush with the side of the computer
Step 12
Replace the 6.5 mm P1 Phillips-head screw that secures the optical drive to the base enclosure.
Step 13
Insert the rear edge of the battery into the battery bay and lower the battery until it is properly seated and the battery release latch clicks.
Replacing the battery into its bay
Step 14
Slide the battery lock to the lock position to secure the battery.
Sliding the battery latch lock into the lock position
