HP EliteDisplay E222 21.5-inch Monitor Product Specifications
Product image
Figure : HP EliteDisplay E222 21.5-inch Monitor
Product features
Feature
Model
M1N96AA
Panel active area
47.06 x 26.77 cm (18.74 x 10.54 in)
54.61 cm (21.5 in) widescreen
Panel
Specification
Model
M1N96AA
Type
21.5-inch IPS with LED backlight
59.9 cm (23.6 in)
Panel active area (W x H)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical
Brightness
250 cd/m
Contrast ratio (typical)
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response time (typical)
7 ms (gray to gray)
Pixel pitch
0.24795 (H) x 0.24795 (V) mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Can display up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
User controls
Specification
Buttons or switches
Dynamically adjust depending upon OSD screen selected
Languages
English, French, German, Italian, Japanese, Netherlands, Portuguese Brazilian, Traditional Chinese, Simplified Chinese, and Spanish
On-screen display (OSD) user controls
Brightness, Contrast, Image Control, Color, Quick View, Language, Management, Information, Factory Reset, Exit
Signal interface/performance
Specification
Horizontal frequency
30-80 kHz
Vertical frequency
50-75 Hz
Native resolution
Preset graphic modes (non-interlaced)
1920 X 1080 at 60 Hz
1680 X 1050 at 60 Hz
1600 X 900 at 60 Hz
1440 X 900 at 60 Hz
1280 X 1024 at 60 Hz
1280 X 800 at 60 Hz
1280 X 720 at 60 Hz
1024 X 768 at 60 Hz
800 X 600 at 60 Hz
640 X 480 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) HDMI
(1) DisplayPort 1.2
HDCP support on DisplayPort and HDMI
USB
(3) USB 2.0 (two downstream and one upstream)
Cables included
(1) DisplayPort: 1.8 m (5.9 ft)
(1) VGA: 1.8 m (5.9 ft)
(1) USB cable: 1.8 m (5.9 ft)
Audio
N/A
Speakers
N/A
Power
Specification
Power supply
Internal
Input power
100-240 V at 50/60 Hz
Maximum power
35 W
Typical power
23 W
Sleep power
0.5 W (standby)
Power cable length
1.9 m (6.2 ft)
What is in the box?
Specification
Monitor and accessories
AC power cord: 1.8 m (5.9 ft)
DisplayPort cable: 1.8 m (5.9 ft)
VGA cable: 1.8 m (5.9 ft)
USB cable: 1.8m (5.9 ft)
Documentation
CD (includes user guide, warranty, and drivers)
HP Display Assistant
Physical specifications
Specification
Dimensions (W x D x H)
Unpacked with stand: 51.37 x 18.9 x 33.35 cm (20.22 x 7.44 x 13.13 in)
Unpacked without stand (head only): 51.37 x 4.98 x 31.69 cm (20.22 x 1.96 x 12.48 in)
Packaged: 60 x 22.5 x 40 cm (23.62 x 8.86 x 15.75 in)
Head only: 3.26 kg (7.19 lb)
Unpacked with stand: 5.27 kg (11.62 lb)
Packaged: 7.18 kg (15.83 lb)
Detachable stand
Yes
Height adjustable
Yes, 150 mm
Tilt range
-5° to +20° (adjust in highest position)
0° to +25° degrees (adjust in lowest position)
Swivel
±45°
Pivot
90°
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,400 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes (except cables)
Mercury-free display backlighting
Yes
Miscellaneous
Specification
User guide languages
Arabic, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Brazilian Portuguese, Russian, Slovenian, Spanish, Swedish, Simplified Chinese, Traditional Chinese, and Turkish
Warranty languages
Color
Black bezel
Silver stand
VESA mounting
100 mm VESA mount
Security lock-ready
Yes
Country of origin
China
