Document ID: c04762280
Version: 1
System BIOS Update 01.08 for HP EliteBook Folio 1020 G1 and 1020 G1 Special Edition
Release date : 04-Aug-2015
Last updated : 04-Aug-2015
DETAILS OF CHANGE
  • Updated to support Windows 10.
  • Updated to the latest Intel Reference Code 2.8.0.
  • Updated to the latest microcode version P48.
  • Added a new F10 (BIOS) Setup option that allows password protection for the F9 and F12 menus.
  • Added the new Intel VBIOS version 5.5.1038.B.13.
  • Fixed an intermittent issue where the TouchPad and keyboard light may not be functional when in F10 (BIOS) Setup.
  • Fixed an issue where the computer would not report an error at POST when Computrace and Secure Boot were enabled.
REASON FOR CHANGE
Quarterly refresh for factory and Web release only.
IMPACT OF CHANGE
If computer is updated from version 01.05 or older to version 01.08, is possible that computer could power off instead of auto-booting right after BIOS flash completion. If this happens, press the Power button and the computer will power on normally. To avoid this, it is recommended to upgrade to version 01.07 first.
The SoftPaq release for version 01.08 will automatically upgrade to 01.07 first, if it detects a BIOS version older or the same as 01.05. Running the SoftPaq a second time will upgrade to 01.08.
If the computer has version 01.06 or newer, then SoftPaq 01.08 will upgrade directly to 01.08.
Components affected:
HP EliteBook Folio 1020 G1 and HP EliteBook Folio 1020 G1 Special Edition
DATE OF CHANGE
Effective date : 29-Jul-2015
Hardware platforms affected : HP EliteBook Folio 1020 G1 Notebook PC, HP EliteBook Folio 1020 G1 Special Edition Notebook PC
