Figure : HP EliteDisplay E232 23-inch Monitor
Feature
Model
M1N98AA - HP EliteDisplay E232 23-inch Monitor
N2Q02AA - HP EliteDisplay E232 23-inch Monitor head only
Panel active area
50.92 x 28.64 cm (20.05 x 11.27 in)
Resolution
1920 x 1080 at 60 Hz
Specification
Model
N2Q02AA - HP EliteDisplay E232 23-inch Monitor Head Only
Type
23-inch IPS with LED backlight
58.42 cm (23 in) widescreen
Panel active area (W x H)
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal/178° vertical (typical)
Brightness
250 cd/m2
Contrast ratio (typical)
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response times
7 milliseconds gray to gray
Pixel pitch
0.265 (H) x 0.265 (V) mm
Pixels per inch (PPI)
96
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72 percent
Specification
Buttons or switches
Menu, Function, Power
Languages
English, French, German, Italian, Japanese, Netherlands, Portuguese, Spanish, Simplified Chinese, and Traditional Chinese
On-screen display
(OSD) user controls
Brightness, Contrast, Input Control, Color Control, Image Control, Power Control, Menu control, Management, Language, Information
Specification
Horizontal frequency
30-80 kHz
Vertical frequency
50-60 Hz
Native resolution
Preset graphic modes (non-interlaced)
1920 X 1080 at 60 Hz
1680 X 1050 at 60 Hz
1600 X 900 at 60 Hz
1440 X 900 at 60 Hz
1280 X 1024 at 60 Hz
1280 X 800 at 60 Hz
1280 X 720 at 60 Hz
1024 X 768 at 60 Hz
800 X 600 at 60 Hz
640 X 480 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Specification
Plug and play
Yes
Input connectors
(1) DisplayPort 1.2
(1) HDMI
(1) VGA
HDCP support on DisplayPort and HDMI
USB
(3) USB 2.0 (two downstream and one upstream)
Cables included
(1) DisplayPort 1.8 m (5.9 ft)
(1) VGA 1.8 m (5.9 ft)
(1) USB 1.8 m (5.9 ft)
Audio
N/A
Specification
Power supply
Internal
Input power
100-240 VAC 50/60 Hz
Maximum power
35 W
Typical power
28 W
Sleep power
0.5 W (standby)
Power cable length
1.9 m (6.2 ft)
1.83 m (6 ft - head only model)
Specification
Detachable stand
Yes, ships detached (not included on head only model)
Height adjustment
N/A
Tilt range
-5° to +25° (+0/-3)
Swivel
45°
Pivot
90°
Specification
Monitor and accessories
HP EliteDisplay E232 23-inch Monitor and column stand or HP Elite E232 23-inch monitor head only
AC power cord: 1.8 m (5.9 ft) or 1.83 m (6 ft) (head only model)
DisplayPort cable: 1.8 m (5.9 ft)
VGA cable: 1.8 m (5.9 ft)
USB cable: 1.8 m (5.9 ft)
Documentation
CD (includes user guide, warranty, and drivers)
HP Display Assistant
Specification
User guide languages
Arabic, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Brazilian Portuguese, Russian, Slovenian, Spanish, Swedish, Simplified Chinese, Traditional Chinese, and Turkish
Warranty languages
Color
Black
VESA mounting
100 mm VESA mount
Security lock-ready
Yes
Country of origin
China
Specification
Dimensions (W x D x H)
Unpacked with stand: 54.93 x 18.9 x 54.99 cm
(21.64 x 7.45 x 21.65 in)
Unpacked without stand (head only): 54.93 x 4.96 x 33.69 cm
(21.64 x 1.95 x 13.27 in)
Packaged: 64 x 22.6 x 41.5 cm
(25.22 x 8.9 x 16.35 in)
Head only: 3.63 kg (8 lb)
Unpacked with stand: 5.7 kg (12.56 lb)
Packaged: 7.3 kg (16.09 lb)
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20-80 percent non-condensing
Non-operating: 5-95 percent, 38.7° C max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes, except cables
Mercury-free display backlighting
Yes
