    Apache Log4j Update
HP Pro Tablet 608 G1 - Specifications
System information
Feature
Preinstalled
  • Windows 8.1 (64-bit)
  • Windows 8.1 Pro (64-bit)
  • Windows 8.1 Pro 64 Retail Solutions (64-bit)
  • Windows Embedded Industry 8.1 (64-bit)
Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
Web-only support
  • Windows 8.1 Enterprise
Processor
Intel Atom x5-Z8500 with Intel HD Graphics (1.44 GHz, up to 2.24 GHz using Intel Burst Technology, 2 MB cache, 4 cores)
Internal: 7.86-inch diagonal capacitive multi-touch, FHD QXGA BrightView WLED UWVA (2048 x 1536)
External: 24-bit per pixel color depth. Various options supported via USB Type-C standard dongles.
Internal storage
Internal storage device
  • 32 GB embedded Multi Media Card (eMMC) (Base SKU)
  • 64 GB embedded Multi Media Card (eMMC)
  • 128 GB embedded Multi Media Card (eMMC)
Micro SD card slot supported
  • Supports SDXC microSD cards up to 2 TB
Memory
2 GB LPDDR3-1600 SDRAM (Transfer rates up to 1600 MT/s)
4 GB LPDDR3-1600 SDRAM (Transfer rates up to 1600 MT/s)
Network/communications
Integrated Wi-Fi
  • Intel Dual Band Wireless-AC 7265 802.11ac WiDi (2x2) Wi-Fi and Bluetooth 4.0 Combo
Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
WWAN
  • WWAN Foxconn NA-1-S3 LTE/EVDO/HSPA+ w/GPS M.2 (746479-002)
  • WWAN Huawei ME906E LTE/HSPA+ w/GPS M.2 (739797-002)
  • WWAN Huawei MU736 HSPA+ w/GPS M.2 (746700-002)
WWAN is an optional feature, requires factory configuration, and use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Contact service provider to determine the coverage area and availability. Connection speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
NFC
  • Near Field Communication (NFC)
Audio/multimedia
Audio
  • HD audio
  • Front facing stereo speakers - 2
  • Integrated audio microphones - 2
  • 3.5 mm combo headphone/microphone jack
Cameras
  • Front camera: 2MP
  • Rear camera: 8MP
Sensors
Ambient Light Sensor
Accelerometer
e-Compass
Gyroscope
Proximity Sensor (WWAN only)
Hall Effect Sensor
Haptics
Feature
BIOS
Secure erase
Measure boot (Windows 8.1 only)
Secure boot (Windows 8.1 only)
Communication
HP mobile connect (Windows 8.1 only)
HP roaming alert (Windows 8.1 only)
Native Miracast support
HP value add software
HP ePrint driver
HP unified recovery manager (Windows 8.1 and 10 only)
HP registration app (Windows 8.1 only)
HP support assistant
Microsoft products
Buy Office
Bing search
Skype
Client security software
Absolute persistence module
HP drive encryption
HP security manager
Microsoft defender (Windows 8.1 only)
Standard
TPM 1.2/2.0
Power
Feature
Power supply
15 W AC Charging Adapter with USB Type-C cable
Battery
21 Whr lithium-polymer
Video playback
Up to 8 hours video playback
Ports/slots
Feature
Ports
USB-Type C - 1
3.5 mm combo headphone/microphone jack - 1
Docking port
MicroSD card slot
System unit
Feature
Stand-alone power requirements (AC power)
Nominal operating voltage: 100-240 V, 50-60 Hz
Temperature
Operating: 0° to 40° C (32° to 104° F)
Non-operating: -20° to 65° C (-4° to 149° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 240 G, 2 ms, half-sine
Random vibration
Operating: 1.043 g
Non-operating: 3.5 g
Industry standard certifications
EMC Compliance - EU/FCC/IC CISPR 22 / EN 55022; CISPR 24 / EN 55024; FCC CFR 47 Part 15 / ICES-003
Yes
Safety Compliance - UL/CSA/CB IEC/CSA/UL/EN 60950-1
Yes
Telecom & SAR Compliance - EU/FCC/IC EN 300 328; EN 300 440; EN 301 489; EN 301 893; EN 301 908; EN 301; EN 62311; EN 62209; EN 62479; FCC 47 CFR Part 2; IC RSS102
Yes
WW - Compliance Americas, APJ, EMEA
Yes
