    Fix HP Printer issue on macOS
HP 3D Capture Stage Product Specifications
The 3D Capture Stage is an accessory for the Sprout by HP PC that assists you in capturing 3D images.
Figure : 3D Capture Stage
3D Capture Stage
Technical specifications
Feature
Specification
Dimensions
Length: 20 cm (7.87 in)
Height: 4 cm (1.57 in)
1 kg (2.2 lb)
Turntable
Motorized, with 360 degree rotation and 15 degree tilt
Restraints
4 rubber magnetized restraints
Scan diameter limit
19 cm (7.48 in)
Weight limit
2 kg (4.5 lb)
Connectivity
USB 3.0
