HP EliteBook 745 G2 Notebook PCs - Overview
Product description
HP 745 G2 Notebook PC
Product features
Feature
AMD A76M Controller Hub (FCH)
Processors
  • AMD A10 Pro-7350B APU (3.3 GHz/2.1 GHz, 4MB L2 cache, 4 cores) with AMD Radeon R6 Graphics
  • AMD A8 Pro-7150B APU (3.2 GHz/2.0 GHz, 4MB L2 cache, 4 cores) with AMD Radeon R5 Graphics
  • AMD A8 Pro-7050B APU (3.0 GHz/2.2 GHz, 1MB L2 cache, 2 cores) with AMD Radeon R4 Graphics
Graphics1
Integrated
  • AMD A10 Pro-7350B Accelerated Processor with AMD Radeon R6 Graphics
  • AMD A8 Pro-7150B APU Accelerated Processor with AMD Radeon R5 Graphics
  • AMD A8 Pro-7050B APU Accelerated Processor with AMD Radeon R4 Graphics
HP EliteBook 745 G2
  • Internal
    14.0-inch diagonal HD anti-glare SVA flat(1366 x 768)
    14.0-inch diagonal HD+ anti-glare SVA flat(1600 x 900)
    14.0-inch diagonal HD+ SVA flat(1600 x 900) Touch
    14.0-inch diagonal FHD anti-glare UWA slim(1920 x 1080)
  • External
    Up to 32-bit per pixel color depth
  • VGA
    Port supports resolutions up to 1920 x 1200 external resolution at 75 Hz
  • DisplayPort
    Supports resolutions up to 3200x2000 at 60Hz
Number of Displays with 2013 UltraSlim Docking Station
3
Storage and drives
  • Hard Drives
    • 320/500GB 7200 rpm SATA II Hard Drive
    • 1TB 7200 rpm SATA II Hard Drive (EliteBook 745 G2 and 755 G2 only)
    • 500GB 7200 rpm SED (Self Encrypting Drive)
    • 500GB 5400 rpm FIPS SED
  • Solid State Drive
    • 128/180/240GB 2.5-inch Solid State Drive
    • 180/256GB SED Solid State Drive
  • HP 3D DriveGuard (Windows only)
    • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
Memory
  • Standard
    DDR3L SDRAM (1600 MHz)
    Two SODIMM slots supporting dual-channel memory
    4GB and 8GB SODIMMs
  • Maximum
    Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
  • Dual-channel
    Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Networking/Communications
  • Wireless
    • Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) is available in select countries. Wireless LAN and integrated Bluetooth are also available (both are factory configurable only) and can be combined with any of the supported wireless WAN options.
  • Broadband Wireless (WWAN)
    • HP hs3110 HSPA+ Mobile Broadband Module
    • HP lt4211 LTE/EV-DO/HSPA+ Qualcomm® Gobi 4G Module (US) (Planned to be available July 2014)
    • HP lt4112 LTE/HSPA+ Qualcomm® Gobi™ 4G Module (EMEA, APJ)
  • Wireless LAN (WLAN)
    • Broadcom 802.11 a/b/g/n AC (2x2) and Bluetooth® 4.0
    • Broadcom 802.11a/b/g/n (2x2) and Bluetooth® 4.0
    • Atheros 802.11b/g/n (1x1)
  • Communications
    • Realtek RTL8111EP 10/100/1000* Ethernet NIC with DASH Support
Audio/Multimedia
  • Audio
    HD Audio with DTS Studio Sound
    2 Integrated stereo speakers
    Integrated dual-microphone array; located in the display
    Function keys for microphone mute, volume up, volume down
    Stereo headphone/line out
    Stereo microphone/line in
  • Webcam
    Optional 720p HD webcam
    • HD format (widescreen)
    • Supports videoconferencing (non-HD) and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low light sensitivity
    • Improved dynamic range
    • Skype-ready
Keyboards/Pointing Devices/Buttons and Function Keys
  • Keyboard
    The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and includes an all-metal keyboard deck for greater rigidity. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. Backlit keyboard available as an option.
  • Pointing devices
    Touchpad with scroll zone, on/off button with LED indicator, two-way scroll, two pick buttons
  • Buttons and function keys
    Separate discrete buttons provide easy access to WLAN on/off and speaker mute. Function keys provide control of features including: standby mode, display brightness, external display, microphone mute, volume down, and volume up.
Software overview
Feature
  • Preinstalled
    • Windows 8.1 64-bit
    • Windows 8.1 Pro 64-bit
    • Windows 7 Professional 64-bit (available through downgrade rights from Windows 8.1 Pro 64- bit)
    • Windows 7 Professional 32
    • Windows 7 Home Premium 32
    • Windows 7 Home Premium 64
    • FreeDOS 2.0
  • Web support
    • Windows 7 Enterprise 64/32, Windows 7 Ultimate 64/32, Windows 8.1 Enterprise 64
Preinstalled software with Windows operating system
  • BIOS
    • HP BIOSphere
    • HP Sure Start
    • HP DriveLock | HP Automatic Drive Lock
    • HP BIOS Protection
    • HP Disk Sanitizer
    • HP SpareKey
    • Update via Network
    • Master Record Security
    • Power On Authentication
    • Pre-Boot Security
    • Secure Erase
    • Hybrid Boot
    • Measured Boot
    • Secure Boot
    • Absolute Persistence Module
  • Communication
    • HP Connection Manager (Windows 7 only)
    • HP GPS and Location
    • HP Mobile Connect (Windows 8.1 in select countries only)
    • HP Wireless Hotspot (Windows 8.1 only)
    • HP Roaming Alert
  • MultiMedia
    • CyberLink PowerDVD
  • HP Value Add Software
    • Getting Started with Windows 8.1
    • HP 3D DriveGuard (Windows required)
    • HP ePrint Driver (HP Exclusive)
    • HP Hotkey Support
    • HP PageLift (HP Exclusive with Windows 8.1)
    • HP Recovery Manager (Windows 7 only)
    • HP Support Assistant W8
    • HP Recovery Disc Creator (Windows 7 only)
    • UEFI System Diagnostics W8
  • 3rd Party
    • Adobe® Flash Player (Commercial)
    • Bing Search
    • Skype
    • Buy Office
    • Lync Optimized
Security
  • Standard Security Features
    • HP Client Security with Credential Manager and Password Manager (Windows only)
    • HP Device Access Manager with Just in Time Authentication (Windows only)
    • HP Drive Encryption (FIPS 140-2 certified) (Windows only)
    • HP File Sanitizer (Windows only)
    • Microsoft Security Essentials (Windows 7 only)
    • HP Trust Circles Standard (Windows only)
    • Absolute Data Protect (Windows only)
    • TPM Embedded Security Chip 1.2 (EAL4+ Certified)
  • Optional Security Features
    1. HP Fingerprint reader
Country: Flag Bulgaria
