HP DeskJet 1110 Printers - Power Button Light Error Conditions
This document is for HP DeskJet 1110, 1111, 1112, HP DeskJet Ink Advantage 1115 and 1118 printers.
The Power button light on the printer blinks or dims to indicate possible errors with the printer. If your printer has a Power button light that blinks, dims, or does not come on, read the corresponding section that matches the condition of the Power button light.
Figure : Power button light
Image: Power button light.
