HP OfficeJet, DeskJet 3830 Printers - Copying Documents or Photos
This document is for HP OfficeJet 3830, 3831, 3832, 3833, 3834, 3835, DeskJet Ink Advantage 3835, 3836, and 3838 All-in-One printers.
You can use your printer to produce copies of printed documents and photos.
Step 1: Load the original document or photo
Load the original document in the Automatic Document Feeder (ADF) tray or on the scanner glass.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Load the original document or photo:
    • ADF: Place the document into the document feeder tray with the print side face up with the top edge in the tray first. Adjust the width guides to fit the item.
      Figure : Place the item print side up into the ADF
      Image: Place the item print side up into the ADF
      Do not load photo paper in the ADF. Use the scanner glass instead to prevent damage to photos.
    • Scanner glass: Place the document with the print side down on the scanner glass, position it according to the engraved guides around the glass, and then close the scanner lid.
      Figure : Position the item print side down on the scanner glass
      Image: Position the item print side down on the scanner glass
Step 2: Copy the document or photo
After loading the paper, change the copy settings such as paper size, paper type, and lightness/darkness level, and then copy the document or photo.
  1. From the Home screen on the printer control panel, touch the Copy icon ().
  2. Swipe to the desired number of copies, or touch the keypad icon (), and then input a number.
  3. Touch the Settings icon (), and then specify desired advanced copy settings:
    • Tray and Paper: Select the paper size and paper type. Make sure that the input tray is loaded with paper.
      The paper size and paper type options only display when the printer detects that paper is being placed in the input tray.
    • Resize: Select the size of the image of the photo or document that you want to copy:
      • Actual: Make a copy that is the same as the size of the original. The margins of the copied image may be clipped.
      • Fit to page: Make a copy that is centered with a white border around the edges. The resized image is either enlarged or reduced to fit the size of the selected output paper.
      • Custom: Increase the size of the image by selecting values greater than 100% or reduce the image size by selecting values less than 100%.
    • Lighter/Darker: Slide the button to select the lightness/darkness level, and then touch OK.
    • ID Card Copy: Make a copy of both sides of an ID card from the scanner glass.
  4. Touch Back () to return to the Copy screen.
  5. Touch Start Black or Start Color to start the copy job.
