    Windows 11 Upgrade Guide
HP DeskJet 1110, 1200 Printers - Replacing Ink Cartridges
This document is for HP DeskJet 1110, 1111, 1112, 1210, 1212, 1255, DeskJet Ink Advantage 1115, 1118, 1216, and 1275 printers.
Replace ink cartridges that are low or out of ink with new, genuine HP ink cartridges.
Step 1: Load paper
Before you replace the ink cartridges and begin the alignment process, load paper in the printer.
  1. Raise the input tray.
    Figure : Raise the input tray
    Image: Raise the input tray
  2. Remove any paper from the input tray that is different than the type of paper you want to load, and then slide the paper width guide as far as possible to the left.
    Figure : Slide the paper width guide to the left
    Image: Slide the paper width guide to the left
  3. Load a stack of U.S. letter, A4, or legal size paper into the input tray with the short edge down and the print side facing you. Push the stack into the tray until it stops.
    Figure : Load the paper into the input tray
    Image: Load the paper into the input tray
  4. Slide the paper width guide to the right until it rests at the edge of the paper. Do not push the guides in so tightly that they bind against the paper.
    Figure : Slide the paper width guide to the right
    Image: Slide the paper width guide to the right.
  5. Lower the output tray, and then pull out the output tray extender.
    Figure : Lower the output tray and pull out the output tray extender
    Image: Lower the output tray and pull out the output tray extender.
Step 2: Replace the ink cartridges
Replace one or both ink cartridges.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Lower the output tray, if it is not already lowered.
  3. Reach inside the printer, grasp the handle, then lower the ink cartridge access door.
    The carriage moves to the center of the printer.
    Figure : Open the ink cartridge access door
    Image: Open the ink cartridge access door.
  4. Wait until the carriage is idle and silent before you continue.
  5. Lightly press down on the ink cartridge to release it.
    Figure : Press down on the ink cartridge
    Image: Press down on the ink cartridge.
  6. Pull one ink cartridge toward you out of its slot.
  7. Remove the new ink cartridge from its package. Be careful to only touch the black plastic on the ink cartridge.
  8. Remove the plastic tape.
    Figure : Remove the plastic tape
    Image: Remove the plastic tape.
  9. Hold the ink cartridge by its sides with the nozzles toward the printer, then insert the ink cartridge into its correct slot.
    • Insert the black ink cartridge () into the right slot.
    • Insert the tri-color ink cartridge () into the left slot.
  10. Slide the ink cartridge at a slightly upward angle into the empty slot, then gently push up on the ink cartridge until it snaps into place.
    Figure : Push the ink cartridge into its slot
    Image: Push the ink cartridge into its slot until it snaps into place.
  11. Repeat these steps to install the other ink cartridge, if necessary.
  12. Close the ink cartridge access door.
    Figure : Close the ink cartridge access door
    Image: Close the ink cartridge access door.
After loading the paper, the printer automatically prints an alignment page.
The printer only prints an alignment page automatically when new ink cartridges are installed.
Review the list of frequently asked questions about replacing the ink cartridges.
