HP Z27n 27-inch Narrow Bezel IPS Display - Overview
Product Description
Product Features
Feature
Models
K7C09A4, K7C09AT
Type
27-inch IPS with LED backlight
68.47 cm (27 in) widescreen; diagonally measured
Panel active area (W × H)
59.67 x 33.56 cm (23.49 × 13.21 in)
Resolution
2560 x 1440 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical
Brightness
350 cd/m2
Contrast ratio (typical)
1000:1 Static
5,000,000:1 Dynamic (DCR)
Response time
14 ms typical (G-to-G); 8 ms with scalar overdrive
Performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Pixel pitch
0.2331 mm
Pixels per inch (PPI)
108.8 DPI
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
99% sRGB
